1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: EPICS PV for data in Area Detector
To: Iain Marcuson <[email protected]>, "[email protected] >> EPICS Tech Talk" <[email protected]>
Date: Thu, 4 May 2017 01:51:34 +0000
Hi Iain,
Some questions:
> I note there are no NDArrayCallbacks.
Please explain exactly what you mean by that statement.  What are you observing?
- Is your driver calling doCallbacksGenericPointer()?
- Are ArrayCallbacks enabled in your driver?
- Is the NDPluginStdArrays plugin enabled (EnableCallbacks)?  Is it configured to get its data from your driver?  Are the TimeStamp_RBV and UniqueId_RBV records in NDPluginStdArrays updating?
> When I look at $(P)$(R)ArrayData, it appears to be all zeroes except the first value
How are you looking at $(P)$(R)ArrayData, i.e. with what tool?
From: [email protected] [[email protected]] on behalf of Iain Marcuson [[email protected]]
Sent: Wednesday, May 03, 2017 3:43 PM
To: [email protected] >> EPICS Tech Talk
Subject: EPICS PV for data in Area Detector
I am trying to transfer pixel values from an Area Detector driver's private variable into an NDArray for viewing with ImageJ.  I have verified that the ImageJ plugin works.  I have also verified that the test data are generated correctly.  My code follows that of the Mythen driver, except with two dimensions instead of one.  I alloc() an NDArray and copy the pixel values over.  I have verified that the pixel values are transferred correctly to the pImage.  I note there are no NDArrayCallbacks.  When I look at $(P)$(R)ArrayData, it appears to be all zeroes except the first value, which appears to increment on both acquisition and "caget $(P)$(R)ArrayData".  What might I be missing?
Thank you,
Iain.
RE: EPICS PV for data in Area Detector Iain Marcuson
Prev: EPICS PV for data in Area Detector Iain Marcuson
Next: Question about build StreamDevice application lzf neu
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: EPICS PV for data in Area Detector Iain Marcuson
