1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Question about build StreamDevice application
Date: Thu, 4 May 2017 03:04:53 +0000
hi,
In order to build an StreamDevice application,
I use the following commands to build softioc:
makeBaseApp.pl -t example top
makeBaseApp.pl -i -t example top
make
and add the following lines to /top/topApp/src/makefile:
top_LIBS += stream
top_LIBS += asyn
top_DBD += asyn.dbd
top_DBD += stream.dbd
according to the streamDevice manual page 3, the following three lines should be included in my xxxAppInclude.dbd:
registrar(drvAsynIPPortRegisterCommands)
registrar(drvAsynSerialPortRegisterCommands)
registrar(vxi11RegisterCommands)
It seems in my case I should find topInclude.dbd file to add the above three lines.
My problem is
toplnclude.dbd does not exist before execute "make" command in the top directory of my softioc and "make clean" command can delete it from /top/topApp/src/O.Common folder.
I have no idea do I miss somthing or anyother method to cope with my problem.
Any help will be appreciated and thanks in advance !
Zhefu
RE: Question about build StreamDevice application Mark Rivers
Prev: RE: EPICS PV for data in Area Detector Mark Rivers
Next: RE: EPICS PV for data in Area Detector Iain Marcuson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: EPICS PV for data in Area Detector Iain Marcuson
Next: RE: Question about build StreamDevice application Mark Rivers
