> I suspect the problem could be that you used the wrong
> $(P)$(R)ArrayCallbacks record. That must be set using the $(R) for the
> detector driver (perhaps it is cam1:), while $(P)$(R)EnableCallbacks must be
> set for the $(R) of the NDPluginStdArrays plugin (perhaps image1:). The
> former tells your driver to do callbacks to plugins (and controls the
> if(arrayCallbacks) you said was false. The latter controls whether the
> NDPluginStdArrays plugin subscribes to callbacks from the driver.
> If you set $(P)$(R)ArrayCallbacks for the NDPluginStdArrays plugin instead
> that would control whether that plugin does callbacks to any downstream
> plugins subscribed to it. That would be an unusual thing to do, since normal
> the NDPluginStdArrays plugin is not connected to any downstream plugins.
I had both the NDPluginStdArrays and the camera with the same $(R). Changing that and following your instructions on which callbacks to enable made the acquisition successful.
Thank you,
Iain.
- EPICS PV for data in Area Detector Iain Marcuson
- RE: EPICS PV for data in Area Detector Mark Rivers
- RE: EPICS PV for data in Area Detector Iain Marcuson
Re: Archiver Appliance scripted alias record Shankar, Murali
need to monitor the subArray record field NORD Lussignol Yves
<2017>
2025
2026
Question about build StreamDevice application lzf neu
<2017>
2025
2026
