1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Data type problem in EPICS PV
To: <[email protected]>
Date: Mon, 8 May 2017 10:50:09 -0500
Hi Palak,
Nobody is going to be able to help you without more information. Is this
PV coming from an IOC (which version of Base, what device support are
you using to connect to the PLC, what kind of PLC, what does the record
definition look like), or from some other kind of CA server such as pcaspy?
http://www.catb.org/esr/faqs/smart-questions.html#beprecise
- Andrew
On 05/08/2017 05:08 AM, palak shimpee wrote:
> EPICS PV named “CWS-TXX-F000:mode_request” with INT32 datatype is
> deployed on PLC . Using move instruction in SIMATIC Manager, -1 value is
> passed to DB7.DBW6 with integer datatype. Through this DB7.DBW6 the
> value is passed in “CWS-TXX-F000:mode_request”. But the value being
> updated in “CWS-TXX-F000:mode_request” is 65535. Can I get a solution
> for this?
Data type problem in EPICS PV palak shimpee
Prev: Re: Troubleshoot "Appliance Down" Issue in EPICS Archiver Applianc Shankar, Murali
Next: AreaDetector bindings and RBV propagation Iain Marcuson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Data type problem in EPICS PV palak shimpee
Next: Re: Troubleshoot "Appliance Down" Issue in EPICS Archiver Applianc Shankar, Murali
