I have completed a basic AreaDetector module for my camera and am working on adding enhancements. Presently, I am attempting to add readback of acquisition status. I am unfamiliar with the normal operations of the RBV PVs, but tried manipulating one for practice. The sequence of events is:
1. Start IOC.
2. Caget $(P)$(R)DetectorState_RBV. It is idle.
3. Run acquisition command.
4. Caget $(P)$(R)DetectorState_RBV. It is idle.
5. Caput $(P)$(R)GetStatus 1. PV and function are detailed below. Initially reported value is 0, as expected.
6. Caget $(P)$(R)DetectorState_RBV. It is "Correct" (numeric value 3, as expected from GetStatus code).
7. Caput $(P)$(R)DetectorState_RBV 2.
8. Caget $(P)$(R)DetectorState_RBV. It is "Readout" (as expected from ADBase.template, numeric value 2).
9. Caput $(P)$(R)GetStatus 1. Initially reported value is 3, not 2 as would be expected from step 8.
10. Caget $(P)$(R)DetectorState_RBV. It is "Readout" (numeric value 2), not 3 as would be expected from step 9.
The Get Status code is
if (function == detector_get_status_)
printf("Received SDGetStaus command.\n");
// XXX Does putting a Get make the set take effect?
getIntegerParam(ADStatus, &det_status);
printf("Detector status before set is %i.\n", det_status);
setIntegerParam(ADStatus, 3);
And the GetStatus record is:
record(longout, $(P)$(R)GetStatus)
field(DTYP, "asynInt32")
field(OUT, "@asyn($(PORT),$(ADDR),$(TIMEOUT))SDGETSTATUS")
Why are the values not propagating between parameter library and PVs, and how does one update these readback value PVs?
Thank you,
Iain Marcuson.
- RE: AreaDetector bindings and RBV propagation Mark S. Engbretson
- RE: AreaDetector bindings and RBV propagation Mark Rivers
Re: Data type problem in EPICS PV Andrew Johnson
<2017>
2025
2026
Re: Troubleshoot "Appliance Down" Issue in EPICS Archiver Applianc Shankar, Murali
<2017>
2025
2026
