The prototype allowed for transferring NTNDArrays transparently either to plugins on the same process (zero copy) or to another network node, both functionalities of course provided by pvAccess. I don't think it would work between different processes the way you describe, though. Getting it into areaDetector R5-0 will still require a substantial effort. For what it is worth, NDPva already zero copies an NDArray into an NTNDArray, so you can technically design an areaDetector plugin today that processes this data as an NTNDArray on the same process. Bruno On Tue, May 9, 2017 at 12:12 PM, Mark Rivers <[email protected]> wrote: My understanding is that Bruno Martins from BNL has already prototyped replacing NDArrays with V4 NTNDArrays and using these as the communication mechanism between drivers and plugins.
| ANJ, 21 Dec 2017 |
Home
News
About
Talk
Base
Modules
Extensions
