Subject: RE: AreaDetector bindings and RBV propagation
To: Mark Rivers <[email protected]>, "[email protected] >> EPICS Tech Talk" <[email protected]>
Date: Wed, 10 May 2017 13:11:42 +0000
Thank you for your response, and sorry for not getting back to you sooner.
> >10. Caget $(P)$(R)DetectorState_RBV.  It is "Readout" (numeric value 2),
> not 3 as would be expected from step 9.
> That does not make sense to me.  If your driver called
> setIntegerParam(ADStatus, 3) and then callParamCallbacks(addr) then the
> record should have the value 3, not 2.
I found that when I toggled the passed to ADStatus (alternating from 3 to 4 and back), the caget read the new value.  It looks like it only updates on change.
Iain.
> -----Original Message-----
> From: [email protected] [
> The Get Status code is
> if (function == detector_get_status_)
>       printf("Received SDGetStaus command.\n");
>       // XXX Does putting a Get make the set take effect?
>       getIntegerParam(ADStatus, &det_status);
>       printf("Detector status before set is %i.\n", det_status);
>       setIntegerParam(ADStatus, 3);
> And the GetStatus record is:
> record(longout, $(P)$(R)GetStatus)
> 	field(DTYP, "asynInt32")
> 	field(OUT, "@asyn($(PORT),$(ADDR),$(TIMEOUT))SDGETSTATUS")
RE: AreaDetector bindings and RBV propagation Mark Rivers
AreaDetector bindings and RBV propagation Iain Marcuson
Prev: Re: Switched PDUs with EPICS support [email protected]
Next: RE: AreaDetector bindings and RBV propagation Mark Rivers
Prev: RE: AreaDetector bindings and RBV propagation Mark Rivers
