1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EDM questions
To: [email protected]
Date: Sat, 20 May 2017 19:28:32 -0400
On 5/18/17 4:55 PM, Zelazny, Michael Stanley wrote:
Select the widget with left-mouse-click then middle-mouse-click and use Group and Ungroup.
From: [email protected] [[email protected]] on behalf of lzf neu [[email protected]]
Sent: Thursday, May 18, 2017 06:55
Subject: EDM questions
hi,
I have two questions to consult you:
1) I want to control a object ( a circle for example) visible or invisible by two PVs. Let me assume PVa and PVb :
if PVa=1 and PVb=1 then the visibility of the circle is invisible otherwise is visible.
I open the circle properties window and have no idea how to process two PV names in Visibility PV blank.
First off, I must point to the edm documentation for CALC\ and LOC\ variables.
https://ics-web.sns.ornl.gov/edm/eum.html#idp216560
To use logic to make a widget visible based on the values of two or more PVs, you will need to use a CALC _expression_ in the visibility PV field of the widget. The screenshot below uses two LOC\ PVs in the calculation, you can replace these with real PVs.
CALC\{A&&B}(LOC\PVa,LOC\PVb)  ---- -> If A is true and B is true then CALC is true.
2) how to control a text update widget visible or invisible according to PV.
however, there is no Visibility PV blank to fill in in Text update properties window.
As Zelazny replied earlier, you need to create a group for the widget you want to use visibility on. The group properties provide the attributes for visibility.
Cheers,
Tim
EDM questions lzf neu
RE: EDM questions Zelazny, Michael Stanley
Prev: Re: AreaDetector ImageJ viewer problem Mark Rivers
Next: Motor record: No longer issues a stop command when motor already stopped? James.OHea
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: EDM questions Zelazny, Michael Stanley
Next: Troubleshooting the redirection-to-records feature of streamDevice Kevin Peterson
