Subject: |
Troubleshooting the redirection-to-records feature of streamDevice |
Kevin Peterson <[email protected]> |
To: |
EPICS tech talk <[email protected]> |
Date: |
Thu, 18 May 2017 12:00:42 -0500 |
I wrote stream support for an ADAM-4018 thermocouple reader. The
support has the following "read" record:
record(bo, "$(P)$(R):read") {
field(DTYP, "stream")
field(DESC, "Read thermocouples")
field(ZNAM, "Done")
field(ONAM, "Read")
field(OUT, "@ADAM_4018.proto queryAll($(A),$(P)$(R)) $(PORT)")
field(SDIS, "$(P)$(R):mode")
field(DISV, 1)
This is the definition of queryAll from the protocol file:
queryAll {
out "#\$1";
in
">%(\$2:ai0)f%(\$2:ai1)f%(\$2:ai2)f%(\$2:ai3)f%(\$2:ai4)f%(\$2:ai5)f%(\$2:ai6)f%(\$2:ai7)f";
And each of the ai records has this definition:
record(ai, "$(P)$(R):ai$(C)") {
field(DESC, "Analog input $(C)")
field(PREC, "3")
The read works (when the read record is processed, the eight ai records
get new values) in my development VME (MVME5100, VxWorks 6.9.4.1,
base-3.14.12.3, stream-2-6 from synApps_5_7).
When I move the support to another VME with the same
processor/VxWorks/EPICS configuration, the read doesn't work. When the
read record is processed I see (via asyn traces) that the query command
gets sent to the thermocouple reader and a string of eight values is
returned, but none of the eight analog input records gets its VAL
updated, nor do they get processed. I do not see any protocol error
messages. I do see that the read record's VAL field has a value of
"Illegal_Value".
How can I troubleshoot this problem? Does streamDevice provide any
debug capabilities that would allow me to confirm that the protocol
arguments in my queryAll function were expanded correctly?
Kevin
Kevin M. Peterson
(630) 252-8644
[email protected]
Re: soft Timestamp fixed point support Andrew Johnson
Streamdevice waveform - binary data stream with no separator Paduan Donadio, Marcio
<2017>
2025
2026
Re: EDM questions Southern, Tim
<2017>
2025
2026
