Subject: Use case for ao record HOPR != DRVH or LOPR != DRVL?
To: EPICS Tech-Talk <[email protected]>
Date: Tue, 30 May 2017 11:41:38 -0500
Hello, Tech-Talkers!
I understand that for the ao (Analog Output) record, the HOPR and LOPR
fields are used for the display limits and the DRVH and DRVL fields are
used for the control limits.  However, I always end up setting HOPR =
DRVH and LOPR = DRVL.  What's a use case where the display limits would
be different from the control limits (i.e., HOPR != DRVH or LOPR !=
DRVL)?
Thanks!
Lewis
RE: Use case for ao record HOPR != DRVH or LOPR != DRVL? Mark Rivers
Re: Use case for ao record HOPR != DRVH or LOPR != DRVL? Mooney, Tim M.
Re: Use case for ao record HOPR != DRVH or LOPR != DRVL? Ralph Lange
Re: Use case for ao record HOPR != DRVH or LOPR != DRVL? Nicholas P. DiMonte
Prev: Re: alh Rod Nussbaumer
Next: RE: Use case for ao record HOPR != DRVH or LOPR != DRVL? Mark Rivers
Prev: RE: Configuring multiple ports with variable port numbers for StreamDevice Mark Rivers
