1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: seqChanShow oddities when running through procServ
To: EPICS Tech Talk <[email protected]>
Date: Fri, 2 Jun 2017 20:28:27 +0200
Which version of procServ are you using?
What is your client that you use to connect to procServ?
That sounds more like a problem between your client and the procServ server. Does your client do the telnet protocol? (Which would negotiate things like CR/LF behavior with the procServ server when you connect.)
Cheers,
~Ralph
On Fri, Jun 2, 2017 at 6:57 PM, Southern, Tim <[email protected]> wrote:
I have found an issue with the sequencer command 'seqChanShow', when logged into a softIoc via procServ telnet.
Running this command on a sequencer will output the first channel in the sequencer as expected. For some reason, the terminal does not recognize the linefeed command using the enter key to proceed to the next channel. Instead, I discovered you have to use cntrl-j ?
The sequencer command works normally for a sequencer I run locally?
I am running softIocs on the following systems:
RHEL Linux kernel -  2.6.32-642.1.1.el6.i686
EPICS Version - R3.14.11
Sequencer Version - seq-2.2.3
Tim Southern
seqChanShow oddities when running through procServ Southern, Tim
Prev: RE: seqChanShow oddities when running through procServ Mark Rivers
Next: Re: Any issues with Base-3.16.1-rc1? Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Next: EPICS Base-3.16.1 Released Andrew Johnson
