Subject: RE: seqChanShow oddities when running through procServ
To: "Southern, Tim" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 2 Jun 2017 18:04:25 +0000
Hi Tim,
I do not have that problem.  I have soft IOCs running under procServ and when I type seqChanShow the Enter key works fine to advance to the next channel.
I suspect something is set wrong with your procServ command?  We are invoking procsServ in a script as follows:
# Command definition
procserv = '/usr/local/bin/procServ --logstamp -n "%s_IOC" -L /home/epics/logs/%s.log %s %s'
# Invoke above command for each IOC
        pcmd = procserv % (iocname, iocname, port, cmd)
From: [email protected] [[email protected]] on behalf of Southern, Tim [[email protected]]
Sent: Friday, June 02, 2017 11:57 AM
To: [email protected]
Subject: seqChanShow oddities when running through procServ
I have found an issue with the sequencer command 'seqChanShow', when
logged into a softIoc via procServ telnet.
Running this command on a sequencer will output the first channel in the
sequencer as expected. For some reason, the terminal does not recognize
the linefeed command using the enter key to proceed to the next channel.
Instead, I discovered you have to use cntrl-j ?
The sequencer command works normally for a sequencer I run locally?
I am running softIocs on the following systems:
RHEL Linux kernel -  2.6.32-642.1.1.el6.i686
EPICS Version - R3.14.11
Sequencer Version - seq-2.2.3
Tim Southern
seqChanShow oddities when running through procServ Southern, Tim
Prev: RE: Any issues with Base-3.16.1-rc1? freddie.akeroyd
Next: Re: seqChanShow oddities when running through procServ Ralph Lange
Prev: seqChanShow oddities when running through procServ Southern, Tim
