Subject: Use default value if CA link error
Date: Mon, 5 Jun 2017 09:52:10 +0000
Dear all,
I have a string input record which value is retrieved via CA link. When remote
PV is not available (e.g. missing IOC) I would like to set "EMPTY" as string
input value.
My idea is to use scalcout record from synApps with CA link connected to INAA
and IAAV connected to INPA, defining the output by checking INPA value and
selecting INAA (Ext PV OK) or "EMPTY" constant (Ext PN NC).
Before adding scalcout record to my IOC I would like to know if this is a good
approach. Is there a simpler solution?
Luca
<< Le informazioni contenute in questo messaggio di posta elettronica e relativi allegati sono riservate e confidenziali e ne è vietata la diffusione in qualunque modo eseguita. Qualora Lei non fosse la persona a cui il presente messaggio è destinato, La invitiamo ad eliminarlo e a darcene gentile comunicazione. Quanto precede ai fini del rispetto delle Legge 675/96 e del Decreto Legislativo 30/06/2003 n.196, sulla tutela dei dati personali >>
<< This e-mail is confidential and may well also be legally privileged. If you have received it in error, you are on notice of its status. Please notify us immediately by reply e-mail and then delete this message from your system. Please do not copy it or use it for any purposes, or disclose its contents to any other person: to do so could be a breach of confidence. Thank you for your co-operation. Please contact our IT Helpdesk on +3902380481 or email [email protected] if you need assistance >>
Re: Use default value if CA link error Maurizio Montis
Prev: Re: asyn timeout Paduan Donadio, Marcio
Next: Re: Use default value if CA link error Maurizio Montis
Prev: Re: EPICS Base-3.16.1 Released Johnson, Andrew N.
