Subject: Re: EPICS Base-3.16.1 Released
To: "J. Lewis Muir" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Mon, 5 Jun 2017 16:27:19 +0000
Hi Lewis,
Good question. In general the answer is any API that isn’t in the 3.15.x release series may need updates after we’ve made use of it for a while. Specifically though:
1. The extensible link support and JSON Link APIs (dbJLink.h and dbLink.h) may change to some extent, hopefully not by much but until we have fully implemented CA, DB and PVA links in the new JSON style we won’t know for sure.
2. The current JSON parser doesn’t handle 64-bit integer literals, but the above APIs were modified to allow that fix to be added without changing the method signatures. I don’t know if we modified the channel filter API though.
As always we can’t be sure about the future need for changes, but the above were the main items I was thinking about when I wrote the note below. If I’ve missed anything Michael Davidsaver may have some additional notes.
HTH,
- Andrew
> On Jun 5, 2017, at 9:41 AM, J. Lewis Muir <[email protected]> wrote:
> On 06/02, Andrew Johnson wrote:
>> Note that some of the new APIs included with this release are not
>> considered "final" and may change in the future. Please tell the core
>> developers if you plan to develop software using these APIs.
> Hi, Andrew.
> How do I know which APIs are not considered final?
> Thanks!
> Lewis
EPICS Base-3.16.1 Released Andrew Johnson
Re: EPICS Base-3.16.1 Released J. Lewis Muir
Prev: Re: EPICS Base-3.16.1 Released J. Lewis Muir
Next: EDM X-Y Graph lot widget oddities Eric Norum
Next: Use default value if CA link error Luca Cavalli
