The EDM X-Y Graph widget (1-12-103, but these issues seem to be present in lots of versions) exhibits some unexpected (by me, anyway) behaviour.Here’s the record holding the data: record(waveform, "$(P)$(R)AWG3:pattern") { field(DESC, "AWG 3 pattern") field(DTYP, "asynInt16ArrayOut") field(INP, "@asyn($(PORT) 3 0)")
And here’s the widget configuration. I’ve tried all sorts of combinations of settings (scope/plot, plot-n-and-stop/plot-last-n specify the record as the trigger records, etc.) but the problems appear the same. graphTitle "DAC $(CHAN) AWG Pattern" font "helvetica-medium-r-14.0" 0 "$(P)$(R)AWG$(CHAN):pattern" 0 "$(P)$(R)AWG$(CHAN):pattern.NORD"
Issue 1 — Autoscaling An example plot with NORD=1000 looks as shown below. I find it odd that the autoscaling has decided to start the X-axis at -200 rather than 0 and to end it at 1200 rather than 1000. And why make the Y axis extend below 0?
Issue 2 — Plotting stale data A client has written 100 points to the waveform record. The EDM screen shows:
The client then writes 1000 points to the waveform record — the same shape, but 10 times as many points. The EDM screen shows:
???? The widget has correctly determined the correct number of points, but appears to have taken Y values from the record before the client has filled the last 900 or so points.
Closing the EDM window and reopening it shows the correct result: |
Re: EPICS Base-3.16.1 Released Johnson, Andrew N.
Re: asyn timeout Paduan Donadio, Marcio
<2017>
2025
2026
Re: stream enum Dirk Zimoch
epicsQt release 3.4.3 - at GitHub Andrew C. Starritt
<2017>
2025
2026
ANJ, 21 Dec 2017 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
