Your conversion "\x02%*4s%c%*c%*c%*c%*c%*c%*c%*c%*c%*c%*s" lets me
assume you want to read the character number 6 (after an initial 0x02
and a 4 byte string) as a number. But %c gives not a number but a
string. To read one char as a number use %1d and a longin record.
in "\x02%*4s%1d%*c%*c%*c%*c%*c%*c%*c%*c%*c%*s";
Be aware that %*4s reads less than 4 chars if it finds a space or tab!
Maybe that is not what you want. Try %*4c instead:
in "\x02%*4c%1d%*c%*c%*c%*c%*c%*c%*c%*c%*c%*s";
Dirk
On 05.06.2017 15:28, l123173 wrote:
Hi all,
I met some little question about stream.
After I sent command, I received a sequence of character through stream.
The pv type was stringin and the value of the pv was 1(string) or
0(string).
My question was that, I need the pv value was natural number( 0 or 1
), not string type.
I have tried to change the stringin to ai, some error came out. Then
I think I could use the enum, but I could not know the usage though I tried.
Could someone give some help.
Li xing
My db and proto file.
record(stringin, "$(P)$(R)STAT")
field(DESC, "test")
field(DTYP, "stream")
field(INP, "@devplc2.proto STAT $(PORT) $(A)")
STAT{
out "\x0500FFBR2Y0000402F";
in "\x02%*4s%c%*c%*c%*c%*c%*c%*c%*c%*c%*c%*s";
- stream enum l123173
RE: makeBaseApp.pl Compilation error on Windows x64 freddie.akeroyd
Re: makeBaseApp.pl Compilation error on Windows x64 Saeed Haghtalab
<2017>
2025
2026
RE: stream enum Mark Rivers
EDM X-Y Graph lot widget oddities Eric Norum
<2017>
2025
2026
