1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Arbitrary limit on timeouts?
To: Michael Davidsaver <[email protected]>
Cc: EPICS mailing list <[email protected]>
Date: Wed, 7 Jun 2017 10:44:25 -0700
Thanks for checking the provenance of this.
I can see the usefulness of the sanity check limit to non-negative timeouts but the arbitrary upper limit seems like a bad idea. Maybe it’s too late to change now — there may be some existing code that depends on this.   At the very least the behaviour should be noted in the application developers guide.
On Jun 7, 2017, at 10:38 AM, Michael Davidsaver <[email protected]> wrote:
On 06/07/2017 06:50 PM, Eric Norum wrote:
Why are timeouts for things like epicsEventWaitWithTImeout() limited to
1 hour?
This is for R3.15.4, but I suspect the code is the same in lots of versions.
Since at least 2000 (first occurrence I find).  The commit message
doesn't give any clues.
https://github.com/epics-base/epics-base/commit/8c60195f4b463bff42f6f967da8bc19d6f5ad11d#diff-583652b37e7f98cf7b720e489744ce88R57
Seems rather arbitrary, so I think this could be removed (or enlarged).
Re: Arbitrary limit on timeouts? Johnson, Andrew N.
Arbitrary limit on timeouts? Eric Norum
Re: Arbitrary limit on timeouts? Michael Davidsaver
Prev: Re: Arbitrary limit on timeouts? Michael Davidsaver
Next: Heads-up: JCA/JNI (using native C libraries) will be dropped Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Arbitrary limit on timeouts? Johnson, Andrew N.
