My guess is that the 3600 second timeout might have been thought of as an arbitrary limit intended to avoid wrapping, but this is for the Posix implementation only and I don’t see where such limits would apply anyway. The convertDoubleToWakeTime() routine *only* appears to be used in the Posix implementation of epicsEventWaitWithTimeout(), and since the wakeTime is an absolute time anyway I think we can safely remove the limit.
I will do this in 3.14 and merge up, unless someone objects.
- Andrew
> On Jun 7, 2017, at 1:44 PM, Eric Norum <[email protected]> wrote:
> Thanks for checking the provenance of this.
> I can see the usefulness of the sanity check limit to non-negative timeouts but the arbitrary upper limit seems like a bad idea. Maybe it’s too late to change now — there may be some existing code that depends on this. At the very least the behaviour should be noted in the application developers guide.
>> On Jun 7, 2017, at 10:38 AM, Michael Davidsaver <[email protected]> wrote:
>> On 06/07/2017 06:50 PM, Eric Norum wrote:
>>> Why are timeouts for things like epicsEventWaitWithTImeout() limited to
>>> 1 hour?
>>> This is for R3.15.4, but I suspect the code is the same in lots of versions.
>> Since at least 2000 (first occurrence I find). The commit message
>> doesn't give any clues.
>> https://github.com/epics-base/epics-base/commit/8c60195f4b463bff42f6f967da8bc19d6f5ad11d#diff-583652b37e7f98cf7b720e489744ce88R57
>> Seems rather arbitrary, so I think this could be removed (or enlarged).
- Arbitrary limit on timeouts? Eric Norum
- Re: Arbitrary limit on timeouts? Michael Davidsaver
- Re: Arbitrary limit on timeouts? Eric Norum
RE: Questions about Java channel access client Shroff, Kunal
makeBaseApp.pl Compilation error on Windows x64 Saeed Haghtalab
<2017>
2025
2026
Heads-up: JCA/JNI (using native C libraries) will be dropped Ralph Lange
<2017>
2025
2026
