1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: vxWorks on Linux
To: <[email protected]>
Date: Fri, 9 Jun 2017 09:57:02 -0500
Hi Amit,
On 06/09/2017 04:46 AM, Amit Chauhan wrote:
> If any body is using vxWorks 6.9 and Workbench 3.3 IDE on a Linux host
> then please do let me know on which distribution (Red Hat, Ubuntu etc.),
> version and type (32-bit/64-bit) of Linux are you using the same .
We use that combination here at the APS on Red Hat. We have used the
same installation on RHEL 6.8, 6.9, 7.2 and 7.3, probably only on 64-bit
but I still have a 32-bit RHEL 6.9 box I can check it on if that helps.
We did have to install a compatibility RPM, pangox-compat to get it to
work on RHEL7.
- Andrew
vxWorks on Linux Amit Chauhan
Prev: vxWorks on Linux Amit Chauhan
Next: NFS mount problem from Ubuntu 12.04 Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
