Subject: NFS mount problem from Ubuntu 12.04
Date: Sat, 10 Jun 2017 14:24:21 +0000
Folks,
This is off-topic from epics but I am hoping someone can help.  I have an Ubuntu 12.04 machine (brukertest-1) from which I need to mount a Centos 7 NFS server (corvette).
The Ubuntu machine is running this kernel
bruker@photontest-1:~$ uname -a
Linux photontest-1 3.11.0-15-generic #25~precise1-Ubuntu SMP Thu Jan 30 17:42:40 UTC 2014 i686 i686 i386 GNU/Linux
I need to be able to mount the corvette /usr/local and /home from this machine.
I have added this machine to corvette:/etc/exports and run exportfs –a.
However, when I try to mount corvette I get the following error:
bruker@photontest-1:~$ sudo mount -t nfs corvette:/usr/local /corvette/usr/local
mount: wrong fs type, bad option, bad superblock on corvette:/usr/local,
       missing codepage or helper program, or other error
       (for several filesystems (e.g. nfs, cifs) you might
       need a /sbin/mount.<type> helper program)
       In some cases useful info is found in syslog - try
       dmesg | tail  or so
When I run dmesg on photontest-1 I see the following:
[4283236.931503] RPC: Registered named UNIX socket transport module.
[4283236.931506] RPC: Registered udp transport module.
[4283236.931507] RPC: Registered tcp transport module.
[4283236.931508] RPC: Registered tcp NFSv4.1 backchannel transport module.
[4283236.943157] FS-Cache: Loaded
[4283236.952960] FS-Cache: Netfs 'nfs' registered for caching
When I look at syslog on photontest-1 I see the following:
bruker@photontest-1:~$ sudo tail -1000l /var/log/syslog
Jun 10 08:43:55 photontest-1 kernel: [4283236.931503] RPC: Registered named UNIX socket transport module.
Jun 10 08:43:55 photontest-1 kernel: [4283236.931506] RPC: Registered udp transport module.
Jun 10 08:43:55 photontest-1 kernel: [4283236.931507] RPC: Registered tcp transport module.
Jun 10 08:43:55 photontest-1 kernel: [4283236.931508] RPC: Registered tcp NFSv4.1 backchannel transport module.
Jun 10 08:43:55 photontest-1 kernel: [4283236.943157] FS-Cache: Loaded
Jun 10 08:43:55 photontest-1 kernel: [4283236.952960] FS-Cache: Netfs 'nfs' registered for caching
I found some documentation on setting up NFS in Ubuntu 12.04 here:
https://www.digitalocean.com/community/tutorials/how-to-set-up-an-nfs-mount-on-ubuntu-12-04
It says that I need to install the nfs-common and portmap packages. However, when I try to do that I get the following errors:
bruker@photontest-1:~$ sudo apt-get install nfs-common portmap
Reading package lists... Done
Building dependency tree
Reading state information... Done
Package portmap is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
Package nfs-common is not available, but is referred to by another package.
E: Package 'nfs-common' has no installation candidate
E: Package 'portmap' has no installation candidate
Any idea if the problem is indeed those missing packages, and if so how to install them?
Re: NFS mount problem from Ubuntu 12.04 Michael Davidsaver
Re: NFS mount problem from Ubuntu 12.04 Jani Hakala
Prev: Re: vxWorks on Linux Andrew Johnson
Next: Re: NFS mount problem from Ubuntu 12.04 Michael Davidsaver
