Subject: Re: NFS mount problem from Ubuntu 12.04
Date: Sat, 10 Jun 2017 18:11:59 +0200
> bruker@photontest-1:~$ sudo apt-get install nfs-common portmap
> Any idea if the problem is indeed those missing packages,
If you don't have '/sbin/mount.nfs' (from nfs-common) then yes.
> and if so how to install them?
FYI, "portmap" has been replaced by "rpcbind", though this should be
resolved automatically.
If these are missing then likely a problem with the apt repository
config.  Most likely is that somehow the ubuntu.com repo lines have been
removed/commented out.
First see if any errors are shown by:
> apt-get update
On 06/10/2017 04:24 PM, Mark Rivers wrote:
> Folks,
> This is off-topic from epics but I am hoping someone can help.  I have
> an Ubuntu 12.04 machine (brukertest-1) from which I need to mount a
> Centos 7 NFS server (corvette).
> The Ubuntu machine is running this kernel
> bruker@photontest-1:~$ uname -a
> Linux photontest-1 3.11.0-15-generic #25~precise1-Ubuntu SMP Thu Jan 30
> 17:42:40 UTC 2014 i686 i686 i386 GNU/Linux
> I need to be able to mount the corvette /usr/local and /home from this
> machine.
> I have added this machine to corvette:/etc/exports and run exportfs –a.
> However, when I try to mount corvette I get the following error:
> bruker@photontest-1:~$ sudo mount -t nfs corvette:/usr/local
> /corvette/usr/local
> mount: wrong fs type, bad option, bad superblock on corvette:/usr/local,
>        missing codepage or helper program, or other error
>        (for several filesystems (e.g. nfs, cifs) you might
>        need a /sbin/mount.<type> helper program)
>        In some cases useful info is found in syslog - try
>        dmesg | tail  or so
> When I run dmesg on photontest-1 I see the following:
> [4283236.931503] RPC: Registered named UNIX socket transport module.
> [4283236.931506] RPC: Registered udp transport module.
> [4283236.931507] RPC: Registered tcp transport module.
> [4283236.931508] RPC: Registered tcp NFSv4.1 backchannel transport module.
> [4283236.943157] FS-Cache: Loaded
> [4283236.952960] FS-Cache: Netfs 'nfs' registered for caching
> When I look at syslog on photontest-1 I see the following:
> bruker@photontest-1:~$ sudo tail -1000l /var/log/syslog
> Jun 10 08:43:55 photontest-1 kernel: [4283236.931503] RPC: Registered
> Jun 10 08:43:55 photontest-1 kernel: [4283236.931506] RPC: Registered
> Jun 10 08:43:55 photontest-1 kernel: [4283236.931507] RPC: Registered
> Jun 10 08:43:55 photontest-1 kernel: [4283236.931508] RPC: Registered
> Jun 10 08:43:55 photontest-1 kernel: [4283236.943157] FS-Cache: Loaded
> Jun 10 08:43:55 photontest-1 kernel: [4283236.952960] FS-Cache: Netfs
> I found some documentation on setting up NFS in Ubuntu 12.04 here:
> https://www.digitalocean.com/community/tutorials/how-to-set-up-an-nfs-mount-on-ubuntu-12-04
> It says that I need to install the nfs-common and portmap packages.
> However, when I try to do that I get the following errors:
> Reading package lists... Done
> Building dependency tree
> Reading state information... Done
> Package portmap is not available, but is referred to by another package.
> This may mean that the package is missing, has been obsoleted, or
> is only available from another source
> Package nfs-common is not available, but is referred to by another package.
> E: Package 'nfs-common' has no installation candidate
> E: Package 'portmap' has no installation candidate
> Any idea if the problem is indeed those missing packages, and if so how
> to install them?
> Thanks,
> Mark
NFS mount problem from Ubuntu 12.04 Mark Rivers
Prev: NFS mount problem from Ubuntu 12.04 Mark Rivers
Next: Re: NFS mount problem from Ubuntu 12.04 Jani Hakala
