1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: saving samples
To: EPICS Tech Talk <[email protected]>
Date: Tue, 13 Jun 2017 19:50:17 +0200
One of the functionalities of the compress record is acting as a ring buffer (for scalar values).
For arrays it can do averages. Either average over time, i.e. multiple array samples - like a scope - or average over multiple elements. If you combine two compress records after e.g. a temperature that gets updated every second, you can - in the first step - have a 3600 element time buffer over the last hour, then - in the second step - do a 60:1 average and have a 60 element buffer of the temperature averages of the last 60 minutes.
Cheers,
~Ralph
On Tue, Jun 13, 2017 at 6:06 PM, Miguel Bordalo <[email protected]> wrote:
save in another PV the last sample (scalar) (or more samples) of other PV that is updated periodically.
this is for example: i have the temperature of a room being updated periodically. I want another PV to act as a buffer that stores the last two samples of the room's temperature . And i want to be able to acess them individually of course.
Thanks!
Miguel Bordalo
Licenciado em Engenharia Electrotécnica e de Computadores
Instituto Superior Técnico
[email protected]
On 13 June 2017 at 16:01, Ralph Lange <[email protected]> wrote:
Please clarify a bit further.
What do you mean by "save"?
Write to a file? Store in an archiver? Write to another record?
What kind of PV?
Scalar or array data?
If array: does "last" mean last array in time, or last element in array?
Cheers,
~Ralph
On Tue, Jun 13, 2017 at 4:18 PM, Miguel <[email protected]> wrote:
What is the easiest way to save periodicaly the last sample (or last 2/3 samples) of a certain PV ?
ty
saving samples Miguel
Re: saving samples Ralph Lange
Re: saving samples Miguel Bordalo
Prev: Re: saving samples Miguel Bordalo
Next: Re: How to add userTag to struct timeStamp in NTScalarArray Marty Kraimer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: saving samples Andrew Johnson
Next: How to add userTag to struct timeStamp in NTScalarArray Heinz Junkes
