Subject: Re: How to add userTag to struct timeStamp in NTScalarArray
To: [email protected]
Date: Tue, 13 Jun 2017 13:55:01 -0400
On 06/13/2017 11:53 AM, Heinz Junkes wrote:
In a thread update method I try to set the userTag :
PVIntPtr pvUserTag =  pvStructure->getSubField<PVInt>("timeStamp.userTag");
pvUserTag->put(count++);
but  eget  -r "field(timeStamp.userTag)” demo shows always
demo
structure
     structure timeStamp
         int userTag 0
Any hints?
Danke Heinz
I suspect that you are communicating with a PVRecord that is processed when You do a put.
If the base class process method is called it sets the timeStamp to the current time and also sets the userTag to 0.
Note the following
mrk> pvget -r "timeStamp.userTag" PVRdouble
PVRdouble
structure
    structure timeStamp
        int userTag 0
mrk> pvput -r "timeStamp.userTag" PVRdouble 3
Old :
structure
    structure timeStamp
        int userTag 0
New :
structure
    structure timeStamp
        int userTag 0
But if process is set to false
mrk> pvput -r "record[process=false]field(timeStamp.userTag)" PVRdouble 3
Old :
structure
    structure timeStamp
        int userTag 0
New :
structure
    structure timeStamp
        int userTag 3
PVRdouble
structure
    structure timeStamp
        int userTag 3
Hope this helps.
Marty
How to add userTag to struct timeStamp in NTScalarArray Heinz Junkes
Prev: Re: saving samples Ralph Lange
Next: Re: saving samples Andrew Johnson
Prev: How to add userTag to struct timeStamp in NTScalarArray Heinz Junkes
Next: the newest areaDetector 梁雅翔
