Subject: the newest areaDetector
To: "Mark Rivers" <[email protected]>
Date: Wed, 14 Jun 2017 16:12:05 +0800 (GMT+08:00)
Hi Mark,
   Now I try to update my areadetector, and I downloaded the areadetector from github today.
   And I downloaded the ADCore,ADBinaries-master,ADSimDetector-R2-4,ADSupport-R1-1,ADPilatus-master.
   I met these question when I make it.
   Could you give me some advise. And I use 3.14.15.5, synapps5-8, asyn-4-31.
Liang yx
The outout of make.
[root@dec1264 areaDetector-R2-6]# make
make -C /usr/epics/synApps_5_8/support/areaDetector-R2-6/ADCore-R2-6 install
make[1]: Entering directory `/usr/epics/synApps_5_8/support/areaDetector-R2-6/ADCore-R2-6'
make -C ./configure install
make[2]: Entering directory `/usr/epics/synApps_5_8/support/areaDetector-R2-6/ADCore-R2-6/configure'
perl /usr/epics/base-3.14.12.5/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../..
mkdir O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
	    T_A=linux-x86_64 install
make[3]: Entering directory `/usr/epics/synApps_5_8/support/areaDetector-R2-6/ADCore-R2-6/configure/O.linux-x86_64'
perl /usr/epics/base-3.14.12.5/bin/linux-x86_64/convertRelease.pl checkRelease
make[3]: Leaving directory `/usr/epics/synApps_5_8/support/areaDetector-R2-6/ADCore-R2-6/configure/O.linux-x86_64'
make[2]: Leaving directory `/usr/epics/synApps_5_8/support/areaDetector-R2-6/ADCore-R2-6/configure'
make -C ./ADApp install
make[2]: Entering directory `/usr/epics/synApps_5_8/support/areaDetector-R2-6/ADCore-R2-6/ADApp'
make -C ./Db install
make[3]: Entering directory `/usr/epics/synApps_5_8/support/areaDetector-R2-6/ADCore-R2-6/ADApp/Db'
perl /usr/epics/base-3.14.12.5/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../..
mkdir O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \
make[4]: Entering directory `/usr/epics/synApps_5_8/support/areaDetector-R2-6/ADCore-R2-6/ADApp/Db/O.linux-x86_64'
Installing template file ../../../db/NDArrayBase.template
mkdir ../../../db
Installing template file ../../../db/ADBase.template
Installing template file ../../../db/ADPrefixes.template
Installing template file ../../../db/NDAttribute.template
Installing template file ../../../db/NDAttributeN.template
Installing template file ../../../db/NDCircularBuff.template
Installing template file ../../../db/NDColorConvert.template
Installing template file ../../../db/NDFFT.template
Installing template file ../../../db/NDFile.template
Installing template file ../../../db/NDFileHDF5.template
Installing template file ../../../db/NDFileJPEG.template
Installing template file ../../../db/NDFileMagick.template
Installing template file ../../../db/NDFileNetCDF.template
Installing template file ../../../db/NDFileNexus.template
Installing template file ../../../db/NDFileTIFF.template
Installing template file ../../../db/NDGather.template
Installing template file ../../../db/NDGatherN.template
Installing template file ../../../db/NDOverlay.template
Installing template file ../../../db/NDOverlayN.template
Installing template file ../../../db/NDPluginBase.template
Installing template file ../../../db/NDPosPlugin.template
Installing template file ../../../db/NDProcess.template
Installing template file ../../../db/NDPva.template
Installing template file ../../../db/NDROI.template
Installing template file ../../../db/NDROIStat.template
Installing template file ../../../db/NDROIStatN.template
Installing template file ../../../db/NDROIStat8.template
Installing template file ../../../db/NDScatter.template
Installing template file ../../../db/NDStats.template
Installing template file ../../../db/NDStdArrays.template
Installing template file ../../../db/NDTimeSeries.template
Installing template file ../../../db/NDTimeSeriesN.template
Installing template file ../../../db/NDTransform.template
Installing template file ../../../db/NDAttrPlotAttr.template
Installing template file ../../../db/NDAttrPlotData.template
Installing template file ../../../db/NDAttrPlot.template
make[4]: Leaving directory `/usr/epics/synApps_5_8/support/areaDetector-R2-6/ADCore-R2-6/ADApp/Db/O.linux-x86_64'
make[3]: Leaving directory `/usr/epics/synApps_5_8/support/areaDetector-R2-6/ADCore-R2-6/ADApp/Db'
make -C ./ADSrc install
make[3]: Entering directory `/usr/epics/synApps_5_8/support/areaDetector-R2-6/ADCore-R2-6/ADApp/ADSrc'
mkdir O.Common
make[4]: Entering directory `/usr/epics/synApps_5_8/support/areaDetector-R2-6/ADCore-R2-6/ADApp/ADSrc/O.linux-x86_64'
Installing dbd file ../../../dbd/ADSupport.dbd
mkdir ../../../dbd
Installing generic include file ../../../include/ADCoreVersion.h
mkdir ../../../include
Installing generic include file ../../../include/NDAttribute.h
Installing generic include file ../../../include/NDAttributeList.h
Installing generic include file ../../../include/NDArray.h
Installing generic include file ../../../include/PVAttribute.h
Installing generic include file ../../../include/paramAttribute.h
Installing generic include file ../../../include/functAttribute.h
Installing generic include file ../../../include/asynNDArrayDriver.h
Installing generic include file ../../../include/ADDriver.h
/usr/bin/g++ -c  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall       -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include         ../NDAttribute.cpp
../NDAttribute.cpp:12:25: warning: epicsString.h: No such file or directory
../NDAttribute.cpp:14:25: warning: epicsExport.h: No such file or directory
In file included from ../NDAttribute.cpp:16:
../NDAttribute.h:17:20: warning: ellLib.h: No such file or directory
../NDAttribute.h:18:24: warning: epicsTypes.h: No such file or directory
../NDAttribute.h:66: error: ‘epicsInt8’ does not name a type
../NDAttribute.h:67: error: ‘epicsUInt8’ does not name a type
../NDAttribute.h:68: error: ‘epicsInt16’ does not name a type
../NDAttribute.h:69: error: ‘epicsUInt16’ does not name a type
../NDAttribute.h:70: error: ‘epicsInt32’ does not name a type
../NDAttribute.h:71: error: ‘epicsUInt32’ does not name a type
../NDAttribute.h:72: error: ‘epicsFloat32’ does not name a type
../NDAttribute.h:73: error: ‘epicsFloat64’ does not name a type
../NDAttribute.h:80: error: ‘ELLNODE’ does not name a type
../NDAttribute.h:87: error: variable ‘epicsShareClass NDAttribute’ has initializer but incomplete type
../NDAttribute.h:87: warning: extended initializer lists only available with -std=c++0x or -std=gnu++0x
../NDAttribute.h:88: error: expected primary-expression before ‘public’
../NDAttribute.h:88: error: expected ‘}’ before ‘public’
../NDAttribute.h:88: error: expected ‘,’ or ‘;’ before ‘public’
../NDAttribute.h:92: error: expected constructor, destructor, or type conversion before ‘(’ token
../NDAttribute.h:94: error: expected class-name before ‘(’ token
../NDAttribute.h:95: error: expected initializer before ‘*’ token
../NDAttribute.h:96: error: ‘virtual’ outside class declaration
../NDAttribute.h:97: error: ‘virtual’ outside class declaration
../NDAttribute.h:98: error: ‘virtual’ outside class declaration
../NDAttribute.h:99: error: ‘virtual’ outside class declaration
../NDAttribute.h:100: error: ‘virtual’ outside class declaration
../NDAttribute.h:101: error: ‘virtual’ outside class declaration
../NDAttribute.h:102: error: ‘virtual’ outside class declaration
../NDAttribute.h:103: error: ‘virtual’ outside class declaration
../NDAttribute.h:104: error: ‘virtual’ outside class declaration
../NDAttribute.h:105: error: ‘virtual’ outside class declaration
../NDAttribute.h:106: error: ‘virtual’ outside class declaration
../NDAttribute.h:107: error: ‘virtual’ outside class declaration
../NDAttribute.h:108: error: ‘virtual’ outside class declaration
../NDAttribute.h:109: error: ‘friend’ used outside of class
../NDAttribute.h:110: error: ‘friend’ used outside of class
../NDAttribute.h:113: error: expected unqualified-id before ‘private’
../NDAttribute.h:124: error: expected declaration before ‘}’ token
../NDAttribute.h:93: warning: ‘const char* attrSourceString(NDAttrSource_t)’ declared ‘static’ but never defined
make[4]: *** [NDAttribute.o] Error 1
make[4]: Leaving directory `/usr/epics/synApps_5_8/support/areaDetector-R2-6/ADCore-R2-6/ADApp/ADSrc/O.linux-x86_64'
make[3]: *** [install.linux-x86_64] Error 2
make[3]: Leaving directory `/usr/epics/synApps_5_8/support/areaDetector-R2-6/ADCore-R2-6/ADApp/ADSrc'
make[2]: *** [ADSrc.install] Error 2
make[2]: Leaving directory `/usr/epics/synApps_5_8/support/areaDetector-R2-6/ADCore-R2-6/ADApp'
make[1]: *** [ADApp.install] Error 2
make[1]: Leaving directory `/usr/epics/synApps_5_8/support/areaDetector-R2-6/ADCore-R2-6'
make: *** [/usr/epics/synApps_5_8/support/areaDetector-R2-6/ADCore-R2-6.install] Error 2
RE: the newest areaDetector Mark Rivers
Prev: Re: IOC Severity Report Matt Rippa
Next: RE: the newest areaDetector Mark Rivers
Prev: Re: How to add userTag to struct timeStamp in NTScalarArray Marty Kraimer
