Subject: Re: global variable asub type double
To: Miguel Bordalo <[email protected]>
Date: Thu, 15 Jun 2017 17:25:10 +0200
You need to specify the type of the variable in your .dbd
>     variable(myvariable)
is a shorthand for
>     variable(myvariable, int)
then replace 'int' with 'double'.
On 06/15/2017 05:09 PM, Miguel Bordalo wrote:
> hello,
> I would like to create a global variable of type double in my asub
> routine c program.
> Following the example and for an integer type if I add
> to .c file:
>     int myvariable;
>     epicsExportAddress(int, myvariable);
> to .dbd file:
> to st.cmd
>      var myvariable 60
> indeed the integer variable is initialized as 60 and i can change it in
> runtime. although if i change the variable to double it gives me an
> error compiling.
> Ty
> *Miguel Bordalo*
> Licenciado em Engenharia Electrotécnica e de Computadores
> Instituto Superior Técnico
> [email protected] <mailto:[email protected]>
global variable asub type double Miguel Bordalo
Prev: global variable asub type double Miguel Bordalo
Next: MEDM to EDM Conversion Script Stubbs, Scott A.
