Subject: Re: Problem compiling EPICS ioc with libusb
To: Michael Westfall <[email protected]>
Date: Thu, 22 Jun 2017 17:29:20 -0700
Hi Mike,
    Thanks for the tip. I've applied your recommended changes and I'm still having trouble compiling. Here's the result now:
make -C ./configure install
make[1]: Entering directory `/media/Extra_Space/work/testIOC/configure'
perl ../../epics/epics3.14-3.14.12.3/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../..
mkdir O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../.. T_A=linux-x86_64 install
make[2]: Entering directory `/media/Extra_Space/work/testIOC/configure/O.linux-x86_64'
perl ../../../epics/epics3.14-3.14.12.3/bin/linux-x86_64/convertRelease.pl checkRelease
make[2]: Leaving directory `/media/Extra_Space/work/testIOC/configure/O.linux-x86_64'
make[1]: Leaving directory `/media/Extra_Space/work/testIOC/configure'
make -C ./testApp install
make[1]: Entering directory `/media/Extra_Space/work/testIOC/testApp'
make -C ./src install
make[2]: Entering directory `/media/Extra_Space/work/testIOC/testApp/src'
perl ../../../epics/epics3.14-3.14.12.3/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../..
mkdir O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. T_A=linux-x86_64 install
make[3]: Entering directory `/media/Extra_Space/work/testIOC/testApp/src/O.linux-x86_64'
perl ../../../../epics/epics3.14-3.14.12.3/bin/linux-x86_64/makeIncludeDbd.pl base.dbd xxxSupport.dbd dbSubExample.dbd testHello.dbd initTrace.dbd testInclude.dbd
echo "../O.Common/testInclude.dbd : ../Makefile" >> test.dbd.d
Expanding dbd
Installing created dbd file ../../../dbd/test.dbd
echo "../O.Common/xxxRecord.h : ../Makefile" >> xxxRecord.h.d
../../../../epics/epics3.14-3.14.12.3/bin/linux-x86_64/dbToRecordtypeH  -I. -I.. -I../O.Common -I../../../dbd -I../../../../epics/epics3.14-3.14.12.3/dbd ../xxxRecord.dbd xxxRecord.h
Installing generated generic include file ../../../include/xxxRecord.h
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I../../../../epics/epics3.14-3.14.12.3/include/os/Linux -I../../../../epics/epics3.14-3.14.12.3/include       ../xxxRecord.c
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I../../../../epics/epics3.14-3.14.12.3/include/os/Linux -I../../../../epics/epics3.14-3.14.12.3/include       ../devXxxSoft.c
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I../../../../epics/epics3.14-3.14.12.3/include/os/Linux -I../../../../epics/epics3.14-3.14.12.3/include       ../dbSubExample.c
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I../../../../epics/epics3.14-3.14.12.3/include/os/Linux -I../../../../epics/epics3.14-3.14.12.3/include       ../testHello.c
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I../../../../epics/epics3.14-3.14.12.3/include/os/Linux -I../../../../epics/epics3.14-3.14.12.3/include       ../initTrace.c
/usr/bin/ar -rc   libtestSupport.a        xxxRecord.o devXxxSoft.o dbSubExample.o testHello.o initTrace.o
/usr/bin/ranlib libtestSupport.a
/usr/bin/g++ -o libtestSupport.so -shared -fPIC -Wl,-soname=libtestSupport.so -Wl,-hlibtestSupport.so -L/media/Extra_Space/work/epics/epics3.14-3.14.12.3/lib/linux-x86_64        -m64              xxxRecord.o devXxxSoft.o dbSubExample.o testHello.o initTrace.o    -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom   -lpthread   -lreadline -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64/libtestSupport.so
Installing library ../../../lib/linux-x86_64/libtestSupport.a
perl ../../../../epics/epics3.14-3.14.12.3/bin/linux-x86_64/registerRecordDeviceDriver.pl ../O.Common/test.dbd test_registerRecordDeviceDriver /media/Extra_Space/work/testIOC > test.tmp
mv test.tmp test_registerRecordDeviceDriver.cpp
/usr/bin/g++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64      -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I../../../../epics/epics3.14-3.14.12.3/include/os/Linux -I../../../../epics/epics3.14-3.14.12.3/include       test_registerRecordDeviceDriver.cpp
make[3]: *** No rule to make target `DI_2108_P.o', needed by `test'.  Stop.
make[3]: Leaving directory `/media/Extra_Space/work/testIOC/testApp/src/O.linux-x86_64'
make[2]: *** [install.linux-x86_64] Error 2
make[2]: Leaving directory `/media/Extra_Space/work/testIOC/testApp/src'
make[1]: *** [src.install] Error 2
make[1]: Leaving directory `/media/Extra_Space/work/testIOC/testApp'
make: *** [testApp.install] Error 2
On 17-06-22 04:39 PM, Michael Westfall wrote:
Also, I don't think you want to do this:
I added the header files for a class I created which interfaces with a usb device (these are included in this email) by adding this line to /testAPP/src/testMain.cpp:
    #include "DI-2108-P.cpp"
Instead, in your Makefile, add this:
test_SRCS += DI-2108P.cpp
Mike Westfall
Control Systems Software Engineer
RE: Problem compiling EPICS ioc with libusb Mark Rivers
Problem compiling EPICS ioc with libusb Sam de Jong
Re: Problem compiling EPICS ioc with libusb Michael Westfall
Prev: Re: Problem compiling EPICS ioc with libusb Michael Westfall
Next: Re: Problem compiling EPICS ioc with libusb Hinko Kocevar
Next: RE: Problem compiling EPICS ioc with libusb Mark Rivers
