Subject: Re: Problem compiling EPICS ioc with libusb
To: Michael Westfall <[email protected]>
Date: Fri, 23 Jun 2017 08:40:52 -0700
Thank you for your assistance. I was able to successfully compile after making your suggestions
-Sam
-------- Original message --------
Date:2017-06-23 8:06 AM (GMT-07:00)
To:
Cc: Sam de Jong , [email protected]
Right.
I was just able to compile successfully with these in my Makefile:
testSupport_SRCS += DI-2108-P.cpp
testSupport_SYS_LIBS += usb-1.0
Also, your added source files DI-2108-P.cpp and DI-2108-P-h need to be in the .../testApp/src directory.
Here is the whole  Makefile:
TOP=../..
include $(TOP)/configure/CONFIG
#  ADD MACRO DEFINITIONS BELOW HERE
# xxxRecord.h will be created from xxxRecord.dbd
DBDINC += xxxRecord
# Install xxxSupport.dbd into <top>/dbd
DBD += xxxSupport.dbd
# Build an IOC support library
LIBRARY_IOC += testSupport
# Compile and add the code to the support library
testSupport_SRCS += xxxRecord.c
testSupport_SRCS += devXxxSoft.c
# Link locally-provided code into the support library,
# rather than directly into the IOC application.
# This is required for Windows DLL builds.
testSupport_SRCS += dbSubExample.c
testSupport_SRCS += testHello.c
testSupport_SRCS += initTrace.c
testSupport_LIBS += $(EPICS_BASE_IOC_LIBS)
# Build the IOC application
PROD_IOC = test
# test.dbd will be created and installed
DBD += test.dbd
# test.dbd will include these files:
test_DBD += base.dbd
test_DBD += xxxSupport.dbd
test_DBD += dbSubExample.dbd
test_DBD += testHello.dbd
test_DBD += initTrace.dbd
# test_registerRecordDeviceDriver.cpp derives from test.dbd
test_SRCS += test_registerRecordDeviceDriver.cpp
# Build the main IOC entry point where needed
test_SRCS_DEFAULT += testMain.cpp
test_SRCS_vxWorks += -nil-
# Add support from base/src/vxWorks if needed
#test_OBJS_vxWorks += $(EPICS_BASE_BIN)/vxComLibrary
# Link in the code from our support library
test_LIBS += testSupport
On Fri, Jun 23, 2017 at 4:45 AM, Hinko Kocevar <[email protected]> wrote:
I think he needs
test_SYS_LIBS += usb-1.0
'Cause header file pulls in libisb-1.0/libusb.h
Cheers,
Hinko
On Fri, 23 Jun 2017 at 01:21, Mark Rivers <[email protected]> wrote:
You need to add libusb to testApp/src/Makefile like this:
From: [email protected] [mailto:tech-talk-bounces@aps.anl.gov] On Behalf Of Sam de Jong
Sent: Thursday, June 22, 2017 6:17 PM
To: [email protected]
Subject: Problem compiling EPICS ioc with libusb
Hello EPICS tech-talk,
    I am trying to compile an EPICS IOC with libusb included (I am on a linux platform running ubuntu 14.04 and EPICS base 3.14-3.14.12.3 ).
    I created the ioc using
    makeBaseApp.pl -t example test
    makeBaseApp.pl -t example -i -a linux-x86_64 test
and was able to run make with no issues.
I added the header files for a class I created which interfaces with a usb device (these are included in this email) by adding this line to /testAPP/src/testMain.cpp:
    #include "DI-2108-P.cpp"
when I try to make, I get this output:
make -C ./configure install
make[1]: Entering directory `/media/Extra_Space/work/testIOC/configure'
make -C O.linux-x86_64 -f ../Makefile TOP=../.. T_A=linux-x86_64 install
make[2]: Entering directory `/media/Extra_Space/work/testIOC/configure/O.linux-x86_64'
perl ../../../epics/epics3.14-3.14.12.3/bin/linux-x86_64/convertRelease.pl checkRelease
make[2]: Leaving directory `/media/Extra_Space/work/testIOC/configure/O.linux-x86_64'
make[1]: Leaving directory `/media/Extra_Space/work/testIOC/configure'
make -C ./testApp install
make[1]: Entering directory `/media/Extra_Space/work/testIOC/testApp'
make -C ./src install
make[2]: Entering directory `/media/Extra_Space/work/testIOC/testApp/src'
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. T_A=linux-x86_64 install
make[3]: Entering directory `/media/Extra_Space/work/testIOC/testApp/src/O.linux-x86_64'
/usr/bin/g++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64      -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I../../../../epics/epics3.14-3.14.12.3/include/os/Linux -I../../../../epics/epics3.14-3.14.12.3/include       ../testMain.cpp
In file included from ../testMain.cpp:14:0:
../DI-2108-P.cpp: In member function ‘std::vector<double> DI_2108_P::getReadings()’:
../DI-2108-P.cpp:202:7: warning: variable ‘r’ set but not used [-Wunused-but-set-variable]
   int r; //for return values
/usr/bin/g++ -o test  -L/media/Extra_Space/work/epics/epics3.14-3.14.12.3/lib/linux-x86_64 -L/media/Extra_Space/work/testIOC/lib/linux-x86_64        -m64              test_registerRecordDeviceDriver.o testMain.o    -ltestSupport -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom
testMain.o: In function `DI_2108_P::Initialize()':
/media/Extra_Space/work/testIOC/testApp/src/O.linux-x86_64/../DI-2108-P.cpp:37: undefined reference to `libusb_init'
/media/Extra_Space/work/testIOC/testApp/src/O.linux-x86_64/../DI-2108-P.cpp:42: undefined reference to `libusb_set_debug'
/media/Extra_Space/work/testIOC/testApp/src/O.linux-x86_64/../DI-2108-P.cpp:44: undefined reference to `libusb_get_device_list'
/media/Extra_Space/work/testIOC/testApp/src/O.linux-x86_64/../DI-2108-P.cpp:51: undefined reference to `libusb_open_device_with_vid_pid'
/media/Extra_Space/work/testIOC/testApp/src/O.linux-x86_64/../DI-2108-P.cpp:56: undefined reference to `libusb_free_device_list'
/media/Extra_Space/work/testIOC/testApp/src/O.linux-x86_64/../DI-2108-P.cpp:58: undefined reference to `libusb_kernel_driver_active'
/media/Extra_Space/work/testIOC/testApp/src/O.linux-x86_64/../DI-2108-P.cpp:63: undefined reference to `libusb_claim_interface'
/media/Extra_Space/work/testIOC/testApp/src/O.linux-x86_64/../DI-2108-P.cpp:60: undefined reference to `libusb_detach_kernel_driver'
testMain.o: In function `DI_2108_P::close()':
/media/Extra_Space/work/testIOC/testApp/src/O.linux-x86_64/../DI-2108-P.cpp:82: undefined reference to `libusb_release_interface'
/media/Extra_Space/work/testIOC/testApp/src/O.linux-x86_64/../DI-2108-P.cpp:89: undefined reference to `libusb_close'
testMain.o: In function `DI_2108_P::sendMessage(std::string)':
/media/Extra_Space/work/testIOC/testApp/src/O.linux-x86_64/../DI-2108-P.cpp:114: undefined reference to `libusb_bulk_transfer'
/media/Extra_Space/work/testIOC/testApp/src/O.linux-x86_64/../DI-2108-P.cpp:118: undefined reference to `libusb_bulk_transfer'
/media/Extra_Space/work/testIOC/testApp/src/O.linux-x86_64/../DI-2108-P.cpp:120: undefined reference to `libusb_strerror'
testMain.o: In function `DI_2108_P::getReadings()':
/media/Extra_Space/work/testIOC/testApp/src/O.linux-x86_64/../DI-2108-P.cpp:208: undefined reference to `libusb_bulk_transfer'
testMain.o: In function `DI_2108_P::reset()':
/media/Extra_Space/work/testIOC/testApp/src/O.linux-x86_64/../DI-2108-P.cpp:74: undefined reference to `libusb_reset_device'
/media/Extra_Space/work/testIOC/testApp/src/O.linux-x86_64/../DI-2108-P.cpp:90: undefined reference to `libusb_exit'
collect2: error: ld returned 1 exit status
make[3]: *** [test] Error 1
make[3]: Leaving directory `/media/Extra_Space/work/testIOC/testApp/src/O.linux-x86_64'
make[2]: *** [install.linux-x86_64] Error 2
make[2]: Leaving directory `/media/Extra_Space/work/testIOC/testApp/src'
make[1]: *** [src.install] Error 2
make[1]: Leaving directory `/media/Extra_Space/work/testIOC/testApp'
make: *** [testApp.install] Error 2
Do you have any idea what might be causing this issue? I've tried googling around and haven't found anything helpful.
Thank you for your assistance,
-Sam de Jong
.. the more I see the less I believe.., AE AoR
Mike Westfall
Control Systems Software Engineer
Prev: RE: modbus write 2 16 bits holding registers with modbus function 16 Mark Rivers
Next: Re: modbus write 2 16 bits holding registers with modbus function 16 Claudio Lambert
Prev: Re: Problem compiling EPICS ioc with libusb Michael Westfall
Next: modbus write 2 16 bits holding registers with modbus function 16 Claudio Lambert
