Subject: ASG local/remote mode problem
To: [email protected]
Date: Wed, 05 Jul 2017 03:58:37 -0400
I want to give access based on local/remote switch at my embedded IOC. For this As per message at tech-talk www.aps.anl.gov/epics/tech-talk/2011/msg00728.php titled "About ASG usage" and www.aps.anl.gov/epics/tech-talk/2009/msg01270.php
1. I have made following acf file
HAG(local) {mylocalIP,127.0.0.1}
HAG(remote){myremoteIP}
ASG(loMode){
	INPA("acndHost:xxxExample:MODE_PV")
	RULE(1,READ)
	RULE(1,WRITE)
		HAG(local)
		CALC("A=0")
ASG(reMode){
	RULE(1,READ)
	RULE(1,WRITE)
		HAG(remote)
		CALC("A=0")
2. I am using default example generated using
makeBaseApp.pl -t example myexample
makeBaseApp.pl -i -t example myexample
and then modified dbExample1.db for field ASG
record(xxx, "$(user):xxxExample")
field(DESC, "xxx record")
field(ASG, "loMode")
field(EGU, "Counts")
field(HOPR, "10")
field(HIHI, "8")
field(HIGH, "6")
field(LOW, "4")
field(LOLO, "2")
field(HHSV, "MAJOR")
field(HSV, "MINOR")
field(LSV, "MINOR")
field(LLSV, "MAJOR")
3. I also added field MODE_PV in record xxx with ASL1
field(MODE_PV,DBF_CHAR) {
		 prompt("MODE VALUE local=0, remote=1")
		 asl(ASL1)
		 pp(TRUE)
4. Also,at ioc shell
epics> dbtr "acndHost:xxxExample"
ACKS: MAJOR         ACKT: YES           ADEL: 0             ALST: 0
ASG: loMode         BKPT: 00            DESC: xxx record    DISA: 0
DISP: 0 DISS: NO_ALARM DISV: 1 DTYP: SoftChannel
EGU: Counts         EVNT: 0             FLNK:CONSTANT 0     HHSV: MAJOR
HIGH: 6             HIHI: 8             HOPR: 10            HSV: MINOR
HYST: 0             INP:CONSTANT        LALM: 2             LCNT: 0
LLSV: MAJOR         LOLO: 2             LOPR: 0             LOW: 4
LSV: MINOR          MDEL: 0             MLST: 0             MODE_PV: 0
NAME: acndHost:xxxExample NSEV: NO_ALARM NSTA: NO_ALARM
PACT: 0             PHAS: 0             PINI: NO            PREC: 0
PRIO: LOW           PROC: 0             PUTF: 0             RPRO: 0
SCAN: Passive       SDIS:CONSTANT       SEVR: MAJOR         STAT: LOLO
TIME: 2017-07-05 13:00:35.793148400     TPRO: 0             TSE: 0
TSEL:CONSTANT       UDF: 0              VAL: 0
5. The asprules at iocshell is showing  the following
epics> asprules
ASG(DEFAULT)
ASG(loMode) {
	INPA(acndHost:xxxExample.MODE_PV) INVALID value=0.000000
	RULE(1,READ,NOTRAPWRITE)
	RULE(1,WRITE,NOTRAPWRITE) {
		HAG(local)
		CALC("A=0") result=TRUE
ASG(reMode) {
		HAG(remote)
		CALC("A=1") result=FALSE
epics>
5. But the command  at local machine shows:
$:cainfo acndHost:xxxExample
acndHost:xxxExample
    State:            connected
    Host:             www.acnd.docsrv:5064
    Access:           read, no write
    Native data type: DBF_DOUBLE
    Request type:     DBR_DOUBLE
    Element count:    1
But the ACCESS is shown as read, no write. instead of READ,WRITE.
6. further trying
epics> dbpf acndHost:xxxExample.MODE_PV,1
DBR_CHAR:           1         0x1
epics> asprules
ASG(DEFAULT)
ASG(loMode) {
		HAG(local)
ASG(reMode) {
		HAG(remote)
Still the rules are not changed...
Please suggest what is going wrong!!!
Best Regards
Sandeep,
B.A.R.C, Mumbai
India
Prev: Re: Plotting X-Y Data from the archive in CSS Michael Davidsaver
Next: devlib2 release 2.9 Michael Davidsaver
