Subject: CSS Text entry values not updating on PV change
To: "[email protected] >> EPICS Tech Talk" <[email protected]>
Date: Wed, 5 Jul 2017 13:40:53 +0000
I am trying to update some text entry boxes with values from the IOC.  The controller ultimately sends and receives many parameters as a single block.  I have set up the IOC to have separate getters and setters that batch the values and transmit them.  I have text entry widgets for the setters and text update widgets for the getters.  What I would like to do on a Get operation is populate the setter widgets with the getter values.  I have tested this with caget and can see that the PV values are populated when I do a get, but the values in the CSS BOY GUI do not update.  Is there some way to populate the text entry widgets from the PV?
Thank you,
Iain.
RE: CSS Text entry values not updating on PV change Mark Rivers
Prev: devlib2 release 2.9 Michael Davidsaver
Next: RE: CSS Text entry values not updating on PV change Mark Rivers
