Subject: RE: CSS Text entry values not updating on PV change
To: Iain Marcuson <[email protected]>, "[email protected] >> EPICS Tech Talk" <[email protected]>
Date: Wed, 5 Jul 2017 13:47:27 +0000
Hi Iain,
Is your driver based on asyn?
If so, your setter records you can add the info tag asyn:READBACK.  This will force the setter (output) records to update their values based on a callback from the driver.  It is documented here:
http://www.aps.anl.gov/epics/modules/soft/asyn/R4-31/asynDriver.html#genericEpicsSupport
From: [email protected] [[email protected]] on behalf of Iain Marcuson [[email protected]]
Sent: Wednesday, July 05, 2017 8:40 AM
To: [email protected] >> EPICS Tech Talk
Subject: CSS Text entry values not updating on PV change
I am trying to update some text entry boxes with values from the IOC.  The controller ultimately sends and receives many parameters as a single block.  I have set up the IOC to have separate getters and setters that batch the values and transmit them.  I have text entry widgets for the setters and text update widgets for the getters.  What I would like to do on a Get operation is populate the setter widgets with the getter values.  I have tested this with caget and can see that the PV values are populated when I do a get, but the values in the CSS BOY GUI do not update.  Is there some way to populate the text entry widgets from the PV?
Thank you,
Iain.
RE: CSS Text entry values not updating on PV change Iain Marcuson
Prev: CSS Text entry values not updating on PV change Iain Marcuson
Next: RE: CSS Text entry values not updating on PV change Iain Marcuson
