1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Why do I need to prevent looping when deploying CA gateway
To: [email protected]
Date: Mon, 24 Jul 2017 23:43:18 +0800 (GMT+08:00)
Dear all,
When I was deploying CA gateways for our facility recently according the users guide [1], I was confused about the motivation for preventing looping mentioned in the document. Does CA gateway looping affect anything? Will CA gateways work improperly when looping happens?
For example, when I create two CA gateways (gateway1 and gateway2) in one PC with eth0 and eth1 connecting to NetA and NetB respectively. Gateway1 binds eth0 as CA server IP and adds eth1/NetB to EPICS_CA_ADDR_LIST, whereas gateway2 binds eth1 as CA server IP and adds eth0/NetA to EPICS_CA_ADDR_LIST. This way, there is a loop and the internal PVs inside both gateway1 and gateway2 can be accessed from both NetA and NetB. However, I cannot see anything abnormal, the two CA gateways still work properly. Even if I capture UDP/TCP packets using Wireshark with cashark plugin, I still cannot see excessive packets.
Any hints or answers are appreciated. Thanks.
Lin
[1] http://www.aps.anl.gov/epics/EpicsDocumentation/ExtensionsManuals/Gateway/Gateway.html
Re: Why do I need to prevent looping when deploying CA gateway Andrew Johnson
Prev: Re: Andor SDK3 issue - AT_WaitBuffer fails Brett Graham
Next: RE: GeniCam support for CamLink cameras Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Why do I need to prevent looping when deploying CA gateway Andrew Johnson
