Subject: RE: GeniCam support for CamLink cameras
To: 'Bruce Hill' <[email protected]>, Techtalk <[email protected]>
Date: Mon, 24 Jul 2017 19:49:52 +0000
This sounds like a good approach.  It would be nice to have in areaDetector.
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Bruce Hill
Sent: Monday, July 17, 2017 8:42 PM
To: Techtalk
Subject: GeniCam support for CamLink cameras
Is anyone looking into using GeniCam to interface w/ CamLink cameras?
We just got a GoldEye CamLink camera in from AlliedVision that only supports GeniCam's GenCP protocol for serial
configuration.    GenCP is a low level binary protocol w/ 2 checksums and an incrementing command id that is used to
read and write camera registers.   The GeniCam concept involves a vendor specific transport layer called a GenTL
Producer that knows how to control and acquire images from the framegrabber, and how to send the GenCP message I/O via
the vendor specific CamLink serial API.
GenCP and the XML files that map camera features to camera registers are also used by the aravisGigE module, but that
module is based on the aravis GTK lib and while it can interface w/ GeniCam compliant gigE and USB cameras, aravis
doesn't follow the GeniCam API so would likely not work w/ a vendor specific GenTL Producer lib.
I think I'll be able to get the basic GoldEye operation working via a streamdevice friendly ASCII register read/write
protocol by wrapping our EDT vendor serial API w/ a GenCP compliant layer. However, from talking to Allied Vision tech
support and EDT tech support, it looks like GeniCam is the going to be the standard before long.
Long term I see a need for an EPICS GeniCam module.   The nice thing about this approach is that a GeniCam module should
work w/ any GeniCam compliant camera, whether it's interface is CamLink, CamLinkHS, GigE, USB3, CoaXPress, etc., as long
as you have the appropriate GenTL library.
Cheers,
- Bruce
Bruce Hill
Member Technical Staff
SLAC National Accelerator Lab
2575 Sand Hill Road M/S 10
Menlo Park, CA  94025
GeniCam support for CamLink cameras Bruce Hill
Prev: Why do I need to prevent looping when deploying CA gateway Wang, Lin
Next: Re: Why do I need to prevent looping when deploying CA gateway Andrew Johnson
Prev: GeniCam support for CamLink cameras Bruce Hill
Next: MEDM 3.1.11 link Jiro Fujita
