On 07/28/2017 11:51 AM, Till Straumann wrote:
> I see that some places (e.g., dbAccess.c: getLinkValue()) impose a limit
> of MAX_STRING_SIZE (still 40).
> How does that play with the PVNAME_STRINGSZ of 61 (base 3.15.5) ?
The use of MAX_STRING_SIZE in dbAccess.c: getLinkValue() is not related
to the PV name length, it's just that a DBF_STRING type is (and will
probably always have to be) fixed at 40 characters. You can use a
DBR_CHAR array type to get strings of any length through the dbAccess
dbGet() API, it does correctly adjust for any length of the underlying
DBF_STRING field (e.g. CALC fields are currently 80 chars).
- Andrew
> On 07/28/2017 08:44 AM, Ralph Lange wrote:
>> Since this may break existing IOCs, I do not expect your suggestion to
>> be accepted into upstream Base easily.
>> Allowing record names of arbitrary length (i.e. allocated) would not
>> increase memory consumption for existing installations, but needs a
>> lot more drastic code changes in crucial places of Base, of course.
+1
- Re: PV / record name length Andrew Johnson
- PV / record name length Sebastian Marsching
- RE: PV / record name length Mark Rivers
- Re: PV / record name length Sebastian Marsching
- Re: PV / record name length Ralph Lange
- Re: PV / record name length Till Straumann
RE: IOC error message on camonitor disconnect freddie.akeroyd
<2017>
2025
2026
<2017>
2025
2026
