Subject: Re: XYgraph pv_name
To: Amien Crombie <[email protected]>, EPICS Tech-Talk <[email protected]>
Date: Wed, 2 Aug 2017 16:05:19 +0000
Hi:
That "pv_name" that you're setting on the BOY XYGraph is basically a macro.
Later, in the Trace 0 Y PV you can then add "$(pv_name)".
When you later, at runtime, update that macro, it's not changing the Y PV used by the trace.
What you'd actually want to change is the "trace_0_y_pv" property.
But I'm not sure the BOY XYGraph supports changing the PVs of a trace at runtime.
-Kay
From: [email protected] <[email protected]> on behalf of Amien Crombie <[email protected]>
Sent: Wednesday, August 02, 2017 7:21 AM
To: EPICS Tech-Talk
Subject: XYgraph pv_name
Hi
I have a script as follows:
link = display.getWidget("linko")
child = link.getChild("xgraph")    # get the xygraph on linko
# here I get the 2 PV's i passed to the script
val= PVUtil.getString(pvs[0])   # this PV is used to switch to the desired opi
dal= PVUtil.getString(pvs[1])   # this is the PV i need
if val=="1.0":
    child.setPropertyValue("pv_name", dal)   # here the correct PV is displayed
    child.setPropertyValue("title",dal)
else:
    # do nothing
So when I call the script, everything works except the xygraph displays no trace. If I do a "PV info" when CSS is running on the graph, it actually shows the graph values.
It looks like the xygraph is not updating the trace at all.
Amien
Re: XYgraph pv_name Amien Crombie
Prev: Re: EPICS Redundancy J. Lewis Muir
Next: Re: Andor SDK3 issue - AT_WaitBuffer fails Brett Graham
Prev: XYgraph pv_name Amien Crombie
Next: Re: XYgraph pv_name Amien Crombie
