Hi Kay
I see what you mean and it looks like you're right in that it
cannot be done in runtime.
To explain my problem:
I have a list of 40 Harps and each Harp has 48 current channels
(waveform). In our current CSS we physically create a 'tabbed'
control with all the 40 harps (one harp per tab). Each tab has a
xygraph control. So when a user selects a specific harp from the
group control, we just make that tab visible etc..
What I want is only 1 xygraph control that gets the PV
name from the 'group' control selected..(see example screen where
I have 3 Harps as example and each Harp has a X and Y graph)
As a point of interest is there a way to instantiate all my Harps
at startup?
I have a separate PVTable with all my PV's in it and saved as
'pvs.sav'.
Can I somehow call this in my code at startup so that all relevant
PV's are created ?
I hope my explanation make sense
regards
Amien
On 02/08/2017 18:05, Kasemir, Kay wrote:
Hi:
That "pv_name" that you're setting on the BOY XYGraph is
basically a macro.
Later, in the Trace 0 Y PV you can then add "$(pv_name)".
When you later, at runtime, update that macro, it's not
changing the Y PV used by the trace.
What you'd actually want to change is the "trace_0_y_pv"
property.
But I'm not sure the BOY XYGraph supports changing the PVs of a
trace at runtime.
-Kay
<[email protected]> on behalf of Amien
Crombie <[email protected]>
Sent:
Wednesday, August 02, 2017 7:21 AM
To: EPICS Tech-Talk
Subject: XYgraph pv_name
Hi
I have a script as follows:
link = display.getWidget("linko")
child = link.getChild("xgraph") # get the xygraph on
linko
# here I get the 2 PV's i passed to the script
val= PVUtil.getString(pvs[0]) #
this PV is used to switch to the desired opi
dal= PVUtil.getString(pvs[1]) # this is the PV i need
if val=="1.0":
child.setPropertyValue("pv_name", dal) # here the
correct PV is displayed
child.setPropertyValue("title",dal)
else:
# do nothing
So when I call
the script, everything works except the xygraph displays
no trace. If I do a "PV info" when CSS is running
on the graph, it actually shows the graph values.
It looks like
the xygraph is not updating the trace at all.
Amien
- Re: XYgraph pv_name Kasemir, Kay
- XYgraph pv_name Amien Crombie
Re: Andor SDK3 issue - AT_WaitBuffer fails Brett Graham
Job openings at ITER Ralph Lange
<2017>
2025
2026
<2017>
2025
2026
ANJ, 21 Dec 2017 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
