Hi Michael,
On 08/15/2017 12:52 PM, Dunning, Michael wrote:
> Thanks for the background info. In my case, I think it's the latter:
> working around limitations of subRecord. But we're hesitant to
> completely rewrite the code because it's very old and very extensive.
> Is there any reason to suspect that defining the macro as I have would
> not work presently, or break in the future?
Defining the macro should continue to work for 3.15.x, 3.16.x and at
least for the first release of EPICS 7; we aren't planning to change the
basic database link implementation for the time-being, but I can't
promise how long that will last. If you can rewrite this code to use the
aSub record type I would recommend that you add that work to your plans
for the medium-term.
BTW since it's being run within the context of a subRecord subroutine
there is no need for your code snippet to be calling dbScanLock() and
dbScanUnlock() on the linked-to record; in 3.14 and above all records
linked together using DB links are placed in the same lock-set. This
might not have been the case when the code was originally written though.
- Andrew
- Re: Replacement for dbGetPdbAddrFromLink ? Dunning, Michael
- Replacement for dbGetPdbAddrFromLink ? Dunning, Michael
- Re: Replacement for dbGetPdbAddrFromLink ? Stubbs, Scott A.
- Re: Replacement for dbGetPdbAddrFromLink ? Michael Davidsaver
Attributes XML problems Hinko Kocevar
<2017>
2025
2026
<2017>
2025
2026
