Hi Iain,
When your driver's writeInt32() function receives new values for SizeX and SizeY it needs to do something that actually causes the image size to change. This is typically a call to the vendor SDK to set the readout area of the detector. Does your detector have this capability? If not, you could implement it in software in your driver, but I would not recommend that. Rather I would suggest that you use the NDPluginROI plugin to select the desired sub-region.
Here is how it is handled in the ADProsilica driver. When the writeInt32() function receives new values for ADBin[X,Y], ADMin[X,Y] , or ADSize[X,Y] it calls setGeometry which makes the calls to the vendor API to set the readout region of the camera.
asynStatus prosilica::writeInt32(asynUser *pasynUser, epicsInt32 value)
int function = pasynUser->reason;
int status = asynSuccess;
tPvUint32 syncs;
static const char *functionName = "writeInt32";
/* Set the parameter and readback in the parameter library. This may be overwritten when we read back the
* status at the end, but that's OK */
status |= setIntegerParam(function, value);
if ((function == ADBinX) ||
(function == ADBinY) ||
(function == ADMinX) ||
(function == ADSizeX) ||
(function == ADMinY) ||
(function == ADSizeY)) {
/* These commands change the chip readout geometry. We need to cache them and apply them in the
* correct order */
status |= setGeometry();
asynStatus prosilica::setGeometry()
int s;
int binX, binY, minY, minX, sizeX, sizeY, maxSizeX, maxSizeY;
static const char *functionName = "setGeometry";
/* Get all of the current geometry parameters from the parameter library */
status |= getIntegerParam(ADBinX, &binX);
if (binX < 1) binX = 1;
status |= getIntegerParam(ADBinY, &binY);
if (binY < 1) binY = 1;
status |= getIntegerParam(ADMinX, &minX);
status |= getIntegerParam(ADMinY, &minY);
status |= getIntegerParam(ADSizeX, &sizeX);
status |= getIntegerParam(ADSizeY, &sizeY);
status |= getIntegerParam(ADMaxSizeX, &maxSizeX);
status |= getIntegerParam(ADMaxSizeY, &maxSizeY);
if (minX + sizeX > maxSizeX) {
sizeX = maxSizeX - minX;
setIntegerParam(ADSizeX, sizeX);
if (minY + sizeY > maxSizeY) {
sizeY = maxSizeY - minY;
setIntegerParam(ADSizeY, sizeY);
/* CMOS cameras don't support binning, so ignore ePvErrNotFound errors */
s = PvAttrUint32Set(this->PvHandle, "BinningX", binX);
if (s != ePvErrNotFound) status |= s;
s = PvAttrUint32Set(this->PvHandle, "BinningY", binY);
if(!status){
status |= PvAttrUint32Set(this->PvHandle, "RegionX", minX/binX);
status |= PvAttrUint32Set(this->PvHandle, "RegionY", minY/binY);
status |= PvAttrUint32Set(this->PvHandle, "Width", sizeX/binX);
status |= PvAttrUint32Set(this->PvHandle, "Height", sizeY/binY);
if (status) asynPrint(this->pasynUserSelf, ASYN_TRACE_ERROR,
"%s:%s: error, status=%d\n",
driverName, functionName, status);
return((asynStatus)status);
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Iain Marcuson
Sent: Thursday, August 17, 2017 3:56 PM
To: [email protected] >> EPICS Tech Talk
Subject: PVs controlling image size in AreaDetector
I am expanding on options for an AreaDetector driver I wrote. The feature I am trying to add is a variable image size. I have set ADMaxSizeX and ADMaxSizeY to the maximum for this sensor type. To change the image size, I am writing to SizeX and SizeY with dbPutField and setIntegerParam followed by callParamCallbacks(). However, the image that comes to the AreaDetector plugin seems to be at the maximum size I specify. What parameters do I change to change the output image size?
Thank you,
Iain Marcuson.
- RE: PVs controlling image size in AreaDetector Iain Marcuson
- PVs controlling image size in AreaDetector Iain Marcuson
Location of plugin attributes in HDF5 Hinko Kocevar
<2017>
2025
2026
<2017>
2025
2026
