1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: PVs controlling image size in AreaDetector
To: Mark Rivers <[email protected]>, "[email protected] >> EPICS Tech Talk" <[email protected]>
Date: Fri, 18 Aug 2017 14:30:34 +0000
SizeX and SizeY are changed somewhat reactively from a different PV.  The detector does have the capacity for a change in image size, and I have verified that the correct number of bytes is being sent by the detector.
Iain.
> -----Original Message-----
> From: Mark Rivers [mailto:[email protected]]
> Sent: Thursday, August 17, 2017 5:37 PM
> To: Iain Marcuson <[email protected]>; tech-
> [email protected] >> EPICS Tech Talk <[email protected]>
> Hi Iain,
> When your driver's writeInt32() function receives new values for SizeX and
> SizeY it needs to do something that actually causes the image size to change.
> This is typically a call to the vendor SDK to set the readout area of the
> detector.  Does your detector have this capability?  If not, you could
> implement it in software in your driver, but I would not recommend that.
> Rather I would suggest that you use the NDPluginROI plugin to select the
> desired sub-region.
> Here is how it is handled in the ADProsilica driver.  When the writeInt32()
> function receives new values for ADBin[X,Y], ADMin[X,Y] , or ADSize[X,Y] it
> calls setGeometry which makes the calls to the vendor API to set the readout
> region of the camera.
> asynStatus prosilica::writeInt32(asynUser *pasynUser, epicsInt32 value) {
>     int function = pasynUser->reason;
>     int status = asynSuccess;
>     tPvUint32 syncs;
>     static const char *functionName = "writeInt32";
>     /* Set the parameter and readback in the parameter library.  This may be
> overwritten when we read back the
>      * status at the end, but that's OK */
>     status |= setIntegerParam(function, value);
>     if ((function == ADBinX) ||
>         (function == ADBinY) ||
>         (function == ADMinX) ||
>         (function == ADSizeX) ||
>         (function == ADMinY) ||
>         (function == ADSizeY)) {
>         /* These commands change the chip readout geometry.  We need to
> cache them and apply them in the
>          * correct order */
>         status |= setGeometry();
> asynStatus prosilica::setGeometry()
>     int s;
>     int binX, binY, minY, minX, sizeX, sizeY, maxSizeX, maxSizeY;
>     static const char *functionName = "setGeometry";
>     /* Get all of the current geometry parameters from the parameter library
>     status |= getIntegerParam(ADBinX, &binX);
>     if (binX < 1) binX = 1;
>     status |= getIntegerParam(ADBinY, &binY);
>     if (binY < 1) binY = 1;
>     status |= getIntegerParam(ADMinX, &minX);
>     status |= getIntegerParam(ADMinY, &minY);
>     status |= getIntegerParam(ADSizeX, &sizeX);
>     status |= getIntegerParam(ADSizeY, &sizeY);
>     status |= getIntegerParam(ADMaxSizeX, &maxSizeX);
>     status |= getIntegerParam(ADMaxSizeY, &maxSizeY);
>     if (minX + sizeX > maxSizeX) {
>         sizeX = maxSizeX - minX;
>         setIntegerParam(ADSizeX, sizeX);
>     if (minY + sizeY > maxSizeY) {
>         sizeY = maxSizeY - minY;
>         setIntegerParam(ADSizeY, sizeY);
>     /* CMOS cameras don't support binning, so ignore ePvErrNotFound errors
>     s = PvAttrUint32Set(this->PvHandle, "BinningX", binX);
>     if (s != ePvErrNotFound) status |= s;
>     s = PvAttrUint32Set(this->PvHandle, "BinningY", binY);
>     if(!status){
>       status |= PvAttrUint32Set(this->PvHandle, "RegionX", minX/binX);
>       status |= PvAttrUint32Set(this->PvHandle, "RegionY", minY/binY);
>       status |= PvAttrUint32Set(this->PvHandle, "Width",   sizeX/binX);
>       status |= PvAttrUint32Set(this->PvHandle, "Height",  sizeY/binY);
>     if (status) asynPrint(this->pasynUserSelf, ASYN_TRACE_ERROR,
>                       "%s:%s: error, status=%d\n",
>                       driverName, functionName, status);
>     return((asynStatus)status);
> Mark
> From: [email protected] [mailto:tech-talk-
> [email protected]] On Behalf Of Iain Marcuson
> Sent: Thursday, August 17, 2017 3:56 PM
> To: [email protected] >> EPICS Tech Talk
> Subject: PVs controlling image size in AreaDetector
> I am expanding on options for an AreaDetector driver I wrote.  The feature I
> am trying to add is a variable image size.  I have set ADMaxSizeX and
> ADMaxSizeY to the maximum for this sensor type.  To change the image size,
> I am writing to SizeX and SizeY with dbPutField and setIntegerParam followed
> by callParamCallbacks().  However, the image that comes to the
> AreaDetector plugin seems to be at the maximum size I specify.  What
> parameters do I change to change the output image size?
> Thank you,
> Iain Marcuson.
RE: PVs controlling image size in AreaDetector Mark Rivers
PVs controlling image size in AreaDetector Iain Marcuson
Prev: RE: Location of plugin attributes in HDF5 Mark Rivers
Next: RE: PVs controlling image size in AreaDetector Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: PVs controlling image size in AreaDetector Mark Rivers
