> I have set ADMaxSizeX and ADMaxSizeY to the maximum for this sensor type. To change the image size,
> I am writing to SizeX and SizeY with dbPutField and setIntegerParam followed by callParamCallbacks().
> However, the image that comes to the AreaDetector plugin seems to be at the maximum size I specify.
> What parameters do I change to change the output image size?
> The detector does have the capacity for a change in image size, and I have verified that the correct number of bytes is being sent by the detector.
The dimensions of the NDArray that your plugins receive is not directly controlled by ADSizeX and ADSizeY.
Rather, it is directly controlled by the dimensions that you pass to NDArrayPool->alloc() when you allocate the new NDArray.
So perhaps you are not correctly setting those dimensions?
-----Original Message-----
Sent: Friday, August 18, 2017 9:31 AM
To: Mark Rivers; [email protected] >> EPICS Tech Talk
Subject: RE: PVs controlling image size in AreaDetector
SizeX and SizeY are changed somewhat reactively from a different PV. The detector does have the capacity for a change in image size, and I have verified that the correct number of bytes is being sent by the detector.
Iain.
> From: Mark Rivers [mailto:[email protected]]
> Sent: Thursday, August 17, 2017 5:37 PM
> To: Iain Marcuson <[email protected]>; tech-
> [email protected] >> EPICS Tech Talk <[email protected]>
> Hi Iain,
> When your driver's writeInt32() function receives new values for SizeX and
> SizeY it needs to do something that actually causes the image size to change.
> This is typically a call to the vendor SDK to set the readout area of the
> detector. Does your detector have this capability? If not, you could
> implement it in software in your driver, but I would not recommend that.
> Rather I would suggest that you use the NDPluginROI plugin to select the
> desired sub-region.
> Here is how it is handled in the ADProsilica driver. When the writeInt32()
> function receives new values for ADBin[X,Y], ADMin[X,Y] , or ADSize[X,Y] it
> calls setGeometry which makes the calls to the vendor API to set the readout
> region of the camera.
> asynStatus prosilica::writeInt32(asynUser *pasynUser, epicsInt32 value) {
> int function = pasynUser->reason;
> int status = asynSuccess;
> tPvUint32 syncs;
> static const char *functionName = "writeInt32";
> /* Set the parameter and readback in the parameter library. This may be
> overwritten when we read back the
> * status at the end, but that's OK */
> status |= setIntegerParam(function, value);
> if ((function == ADBinX) ||
> (function == ADBinY) ||
> (function == ADMinX) ||
> (function == ADSizeX) ||
> (function == ADMinY) ||
> (function == ADSizeY)) {
> /* These commands change the chip readout geometry. We need to
> cache them and apply them in the
> * correct order */
> status |= setGeometry();
> asynStatus prosilica::setGeometry()
> int s;
> int binX, binY, minY, minX, sizeX, sizeY, maxSizeX, maxSizeY;
> static const char *functionName = "setGeometry";
> /* Get all of the current geometry parameters from the parameter library
> status |= getIntegerParam(ADBinX, &binX);
> if (binX < 1) binX = 1;
> status |= getIntegerParam(ADBinY, &binY);
> if (binY < 1) binY = 1;
> status |= getIntegerParam(ADMinX, &minX);
> status |= getIntegerParam(ADMinY, &minY);
> status |= getIntegerParam(ADSizeX, &sizeX);
> status |= getIntegerParam(ADSizeY, &sizeY);
> status |= getIntegerParam(ADMaxSizeX, &maxSizeX);
> status |= getIntegerParam(ADMaxSizeY, &maxSizeY);
> if (minX + sizeX > maxSizeX) {
> sizeX = maxSizeX - minX;
> setIntegerParam(ADSizeX, sizeX);
> if (minY + sizeY > maxSizeY) {
> sizeY = maxSizeY - minY;
> setIntegerParam(ADSizeY, sizeY);
> /* CMOS cameras don't support binning, so ignore ePvErrNotFound errors
> s = PvAttrUint32Set(this->PvHandle, "BinningX", binX);
> if (s != ePvErrNotFound) status |= s;
> s = PvAttrUint32Set(this->PvHandle, "BinningY", binY);
> if(!status){
> status |= PvAttrUint32Set(this->PvHandle, "RegionX", minX/binX);
> status |= PvAttrUint32Set(this->PvHandle, "RegionY", minY/binY);
> status |= PvAttrUint32Set(this->PvHandle, "Width", sizeX/binX);
> status |= PvAttrUint32Set(this->PvHandle, "Height", sizeY/binY);
> if (status) asynPrint(this->pasynUserSelf, ASYN_TRACE_ERROR,
> "%s:%s: error, status=%d\n",
> driverName, functionName, status);
> return((asynStatus)status);
> Mark
> From: [email protected] [mailto:tech-talk-
> [email protected]] On Behalf Of Iain Marcuson
> Sent: Thursday, August 17, 2017 3:56 PM
> To: [email protected] >> EPICS Tech Talk
> Subject: PVs controlling image size in AreaDetector
> I am expanding on options for an AreaDetector driver I wrote. The feature I
> am trying to add is a variable image size. I have set ADMaxSizeX and
> by callParamCallbacks(). However, the image that comes to the
> AreaDetector plugin seems to be at the maximum size I specify. What
> Thank you,
> Iain Marcuson.
- RE: PVs controlling image size in AreaDetector Iain Marcuson
- PVs controlling image size in AreaDetector Iain Marcuson
- RE: PVs controlling image size in AreaDetector Mark Rivers
<2017>
2025
2026
<2017>
2025
2026
