Indeed, changing the dimensions where I alloc() the NDArrayPool creates the correct size image. Thank you.
Iain.
> -----Original Message-----
> From: Mark Rivers [mailto:[email protected]]
> Sent: Friday, August 18, 2017 1:37 PM
> To: Iain Marcuson <[email protected]>; tech-
> [email protected] >> EPICS Tech Talk <[email protected]>
> Subject: RE: PVs controlling image size in AreaDetector
> > I have set ADMaxSizeX and ADMaxSizeY to the maximum for this sensor
> > type. To change the image size, I am writing to SizeX and SizeY with
> dbPutField and setIntegerParam followed by callParamCallbacks().
> > However, the image that comes to the AreaDetector plugin seems to be at
> the maximum size I specify.
> > What parameters do I change to change the output image size?
> > The detector does have the capacity for a change in image size, and I have
> verified that the correct number of bytes is being sent by the detector.
> The dimensions of the NDArray that your plugins receive is not directly
> controlled by ADSizeX and ADSizeY.
> Rather, it is directly controlled by the dimensions that you pass to
> NDArrayPool->alloc() when you allocate the new NDArray.
> So perhaps you are not correctly setting those dimensions?
> Mark
> From: Iain Marcuson [mailto:[email protected]]
> Sent: Friday, August 18, 2017 9:31 AM
> To: Mark Rivers; [email protected] >> EPICS Tech Talk
> SizeX and SizeY are changed somewhat reactively from a different PV. The
> Iain.
> > Sent: Thursday, August 17, 2017 5:37 PM
> > Hi Iain,
> > When your driver's writeInt32() function receives new values for SizeX
> > and SizeY it needs to do something that actually causes the image size to
> change.
> > This is typically a call to the vendor SDK to set the readout area of
> > the detector. Does your detector have this capability? If not, you
> > could implement it in software in your driver, but I would not recommend
> that.
> > Rather I would suggest that you use the NDPluginROI plugin to select
> > the desired sub-region.
> > Here is how it is handled in the ADProsilica driver. When the
> > writeInt32() function receives new values for ADBin[X,Y], ADMin[X,Y] ,
> > or ADSize[X,Y] it calls setGeometry which makes the calls to the
> > vendor API to set the readout region of the camera.
> > asynStatus prosilica::writeInt32(asynUser *pasynUser, epicsInt32 value) {
> > int function = pasynUser->reason;
> > int status = asynSuccess;
> > tPvUint32 syncs;
> > static const char *functionName = "writeInt32";
> > /* Set the parameter and readback in the parameter library. This
> > may be overwritten when we read back the
> > * status at the end, but that's OK */
> > status |= setIntegerParam(function, value);
> > if ((function == ADBinX) ||
> > (function == ADBinY) ||
> > (function == ADMinX) ||
> > (function == ADSizeX) ||
> > (function == ADMinY) ||
> > (function == ADSizeY)) {
> > /* These commands change the chip readout geometry. We need
> > to cache them and apply them in the
> > * correct order */
> > status |= setGeometry();
> > asynStatus prosilica::setGeometry()
> > int s;
> > int binX, binY, minY, minX, sizeX, sizeY, maxSizeX, maxSizeY;
> > static const char *functionName = "setGeometry";
> > /* Get all of the current geometry parameters from the parameter
> > library */
> > status |= getIntegerParam(ADBinX, &binX);
> > if (binX < 1) binX = 1;
> > status |= getIntegerParam(ADBinY, &binY);
> > if (binY < 1) binY = 1;
> > status |= getIntegerParam(ADMinX, &minX);
> > status |= getIntegerParam(ADMinY, &minY);
> > status |= getIntegerParam(ADSizeX, &sizeX);
> > status |= getIntegerParam(ADSizeY, &sizeY);
> > status |= getIntegerParam(ADMaxSizeX, &maxSizeX);
> > status |= getIntegerParam(ADMaxSizeY, &maxSizeY);
> > if (minX + sizeX > maxSizeX) {
> > sizeX = maxSizeX - minX;
> > setIntegerParam(ADSizeX, sizeX);
> > if (minY + sizeY > maxSizeY) {
> > sizeY = maxSizeY - minY;
> > setIntegerParam(ADSizeY, sizeY);
> > /* CMOS cameras don't support binning, so ignore ePvErrNotFound
> > errors */
> > s = PvAttrUint32Set(this->PvHandle, "BinningX", binX);
> > if (s != ePvErrNotFound) status |= s;
> > s = PvAttrUint32Set(this->PvHandle, "BinningY", binY);
> > if(!status){
> > status |= PvAttrUint32Set(this->PvHandle, "RegionX", minX/binX);
> > status |= PvAttrUint32Set(this->PvHandle, "RegionY", minY/binY);
> > status |= PvAttrUint32Set(this->PvHandle, "Width", sizeX/binX);
> > status |= PvAttrUint32Set(this->PvHandle, "Height", sizeY/binY);
> > if (status) asynPrint(this->pasynUserSelf, ASYN_TRACE_ERROR,
> > "%s:%s: error, status=%d\n",
> > driverName, functionName, status);
> > return((asynStatus)status);
> > Mark
> > From: [email protected] [mailto:tech-talk-
> > [email protected]] On Behalf Of Iain Marcuson
> > Sent: Thursday, August 17, 2017 3:56 PM
> > To: [email protected] >> EPICS Tech Talk
> > Subject: PVs controlling image size in AreaDetector
> > I am expanding on options for an AreaDetector driver I wrote. The
> > feature I am trying to add is a variable image size. I have set
> > ADMaxSizeX and ADMaxSizeY to the maximum for this sensor type. To
> > change the image size, I am writing to SizeX and SizeY with dbPutField
> > and setIntegerParam followed by callParamCallbacks(). However, the
> > image that comes to the AreaDetector plugin seems to be at the maximum
> > size I specify. What parameters do I change to change the output image
> size?
> > Thank you,
> > Iain Marcuson.
- PVs controlling image size in AreaDetector Iain Marcuson
- RE: PVs controlling image size in AreaDetector Mark Rivers
- RE: PVs controlling image size in AreaDetector Iain Marcuson
Upgrading to CSS 4.5 Abdalla Ahmad
<2017>
2025
2026
Location of plugin attributes in HDF5 Hinko Kocevar
<2017>
2025
2026
