Hi Hinko,
You can specify where to put each attribute in the HDF file using a different type of XML file that defines the HDF5 file layout. It is documented here:
http://cars.uchicago.edu/software/epics/NDFileHDF5.html
You can tell it a different location for all NDAttributes, or the location of each individual NDAttribute. You cannot tell it to put the NDAttributes from the Stats1 in one location, those from ROI1 in another location etc. as a group, you need to do it for each individual NDAttribute.
From: [email protected] [[email protected]] on behalf of Hinko Kocevar [[email protected]]
Sent: Friday, August 18, 2017 1:44 AM
To: [email protected]
Subject: Location of plugin attributes in HDF5
if I set 13ANDOR1:ROI1:NDAttributesFile to point to some XML and also 13ANDOR1:Stats1:NDAttributesFile I get both attribute lists under /entry/instrument/NDAttributes, along with all the attributes from 13ANDOR1:cam1:NDAttributesFile list.
Can I have them in separate groups?
Hinko
- Location of plugin attributes in HDF5 Hinko Kocevar
RE: PVs controlling image size in AreaDetector Iain Marcuson
<2017>
2025
2026
Upgrading to CSS 4.5 Abdalla Ahmad
<2017>
2025
2026
