1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: New Display Builder widget question using Navigation Tabs
To: "Kasemir, Kay" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 22 Aug 2017 16:41:58 +0200
Hi Kay
Yes, I see now the error of my ways.
In fact I have exactly done what you suggested (making tab larger) and now everything is working.
We can flag this as done and thanks for helping again...appreciated.
One small thing I've notices is that the handy "Grid Layout" is not there anymore, so I have to spend quite some time in aligning my many widgets. But the new Builder sure is worth the effort..
Amien
On 22/08/2017 15:23, Kasemir, Kay wrote:
Hi:
I have a display that host the 'nav tabs'. As you know, the navtabs works (in my case) by having a single bob with 5 groups consisting of widgets etc (you can see the 5 groups on my pic).
So my navtabs works well.
But I want to have an embedded display on the lower part of my navtab that will become visible when I do certain things from my navtab widgets.
I know an embedded display cannot be accessed so I used a 'group' widget that contains the embedded one. So I should be able to access the 'group' widget's visibility setting as it will not change.
So in my script, that is attached to each widget on my navtab, I want to be able to 'show' or hide' the 'group' widget that contains the embedded display..
In a perfect world my script should sends the $(pv_name) down to the embedded display. This is where I am lost now..
I'm still not clear what you have, but let's assume it's somewhat like this:
Main display has navtabs with 5 tabs, i.e. an embedded display that selects one of 5 sub displays Tab1, Tab2, .., Tab 5.
In addition, that main display has another embedded display.
You somehow want to influence that other embedded display from within Tab1, .. Tab5.
The scripts for any of these displays (main, Tab1, .. Tab5, the other embedded display) are all sandboxed to within their display, they cannot locate widgets in other displays.
What you can use to communicate between these is PVs, either real PVs or local PVs.
A script in Tab2 can write to loc://do_something(0) or loc://the_name(""), and a script attached to the other embedded display can react to changes in these local PVs.
I would start to worry, though, that this is morphing from a control system display to a video game.
If the content of the tabs is related to what's shown below, why isn't the stuff below simply included in the tab?
I.e. make the tabs larger and include the other embedded display inside Tab1, Tab2, .., Tab5.
-Kay
Re: New Display Builder widget question using Navigation Tabs Kasemir, Kay
New Display Builder widget question using Navigation Tabs Amien Crombie
Re: New Display Builder widget question using Navigation Tabs Amien Crombie
Prev: Re: New Display Builder widget question using Navigation Tabs Kasemir, Kay
Next: Re: New Display Builder widget question using Navigation Tabs Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
