Subject: Re: CSS-4.5 : Display-Builder : getting widget's PV value
To: "Kasemir, Kay" <[email protected]>, EPICS Tech-Talk <[email protected]>
Date: Thu, 24 Aug 2017 17:55:11 +0200
Kay, I got the print to work...looks like my script is not triggered at the time
When I put a 'Action Button' on my display that calls the script, it works fine..at least with the 'print' I can see where I am now.
Any idea how I can fire my script when the 'widget' becomes 'visible' ? (without my having to add an action-button)
thanks
Amien
On 24/08/2017 15:18, Kasemir, Kay wrote:
Hi:
  According to 'cainfo' my pv is a DBF_DOUBLE and request is DBR_DOUBLE
Well, when I try it with double or int PVs, I do get the value out via PVUtil.getDouble.
When the PV is a string, then PVUtil.getDouble returns nan.
  But I do not know how to check for output with the 'print' statement..
I'm using Mint 18 and CSS is started >without a terminal command (am I doing something wrong?)
Just open a terminal (xterm, gnome-terminal, ...) and then start CSS from within the terminal.
=> In that terminal you can now see the print statements.
If you don't have a terminal (like on MS Windows), you can use the ScriptUtil.
​from org.csstudio.display.builder.runtime.script import ScriptUtil
ScriptUtil.getLogger().warning("Script has a problem")
==> Those messages appear in the console and also in the workspace/.metadata/.log
Finally, the ScriptUtil also allows you to open dialogs:
ScripUtil.showErrorDialog(widget, "I have a problem, pv has value " + str(pv.read()))
-Kay
Re: CSS-4.5 : Display-Builder : getting widget's PV value Kasemir, Kay
CSS-4.5 : Display-Builder : getting widget's PV value Amien Crombie
Re: CSS-4.5 : Display-Builder : getting widget's PV value Amien Crombie
Prev: RE: Problems building seq 2.2.4 on Linux Mark Rivers
Next: Re: CSS-4.5 : Display-Builder : getting widget's PV value Kasemir, Kay
Prev: Re: CSS-4.5 : Display-Builder : getting widget's PV value Kasemir, Kay
