Users of the motor record,
There is an open motor pull-request that would subtly change the
behavior of the motor record VBAS == VELO:
https://github.com/epics-modules/motor/pull/75
Do you have a use-case for the situation where VBAS == VELO? If so,
which version of the motor module are you using?
What do you expect the motor record to do when VBAS == VELO?
Kevin
RE: Problems building seq 2.2.4 on Linux Mark Rivers
Re: Problems building seq 2.2.4 on Linux Sue Witherspoon
<2017>
2025
2026
Re: Running CSS-4.5 from Eclipse Neon Amien Crombie
Job opening at PSI (Control System Specialist) - SwissFEL Athos Photonics Celcer Tine (PSI)
<2017>
2025
2026
