1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problems building seq 2.2.4 on Linux
To: Mark Rivers <[email protected]>, Ben Franksen <[email protected]>, Tech-talk <[email protected]>
Date: Fri, 25 Aug 2017 12:26:57 -0400
Hi Ben, Mark
   Again, thank you for looking at this...
Ben, yes the problem is that snl.h is not getting generated. What triggers the build of snl.h?
Mark, no I confirmed that the distribution lemon.c is being used. Yet, snl.h is still not being generated....???
Sue
On 08/25/2017 07:41 AM, Mark Rivers wrote:
Hi Ben,
I just realized the source of my confusion.  This is the contents of the seq-2.2.4/src/lemon directory in the distributed tar file from your Web site:
corvette:seq-2.2.4/src/lemon>ls -l
total 332
-rw-r--r-- 1 epics domain users    297 Nov 25  2016 Makefile
-rw-r--r-- 1 epics domain users 166115 Nov 25  2016 lemon-orig.c
-rw-r--r-- 1 epics domain users 166802 Nov 25  2016 lemon.c
So the lemon-orig.c file is in the distribution, it is not something I did locally.
If I use the distributed source it works except for the following 3 patches which were done for parallel make and for 2 problems on Windows.  Perhaps these should be added to the Known Problems for 2.2.4.
corvette:~/devel>diff -r -U2 seq-2.2.4 seq-2-2-4
diff -r -U2 seq-2.2.4/documentation/Makefile seq-2-2-4/documentation/Makefile
--- seq-2.2.4/documentation/Makefile    2016-11-25 11:50:20.000000000 -0600
+++ seq-2-2-4/documentation/Makefile    2017-01-15 08:01:05.574745859 -0600
@@ -43,5 +43,5 @@
 realclean clean:
-       -rm -rf $(BUILDDIR)
+       $(RMDIR) $(BUILDDIR)
 runtests:
diff -r -U2 seq-2.2.4/src/snc/Makefile seq-2-2-4/src/snc/Makefile
--- seq-2.2.4/src/snc/Makefile  2016-11-25 11:50:22.000000000 -0600
+++ seq-2-2-4/src/snc/Makefile  2017-01-14 16:04:59.632573044 -0600
@@ -37,4 +37,6 @@
 endif
+HDEPENDS_METHOD=MKMF
 include $(TOP)/configure/RULES
diff -r -U2 seq-2.2.4/src/snc/snl.lt seq-2-2-4/src/snc/snl.lt
--- seq-2.2.4/src/snc/snl.lt    2016-11-25 11:50:22.000000000 -0600
+++ seq-2-2-4/src/snc/snl.lt    2017-01-13 08:35:39.777418847 -0600
@@ -830,9 +830,9 @@
       yy_reduce(yypParser,yyact-YY_MIN_REDUCE);
     }else{
-      assert( yyact == YY_ERROR_ACTION );
-      yyminorunion.yy0 = yyminor;
 #ifdef YYERRORSYMBOL
       int yymx;
 #endif
+      assert( yyact == YY_ERROR_ACTION );
+      yyminorunion.yy0 = yyminor;
 #ifndef NDEBUG
       if( yyTraceFILE ){
If I replace lemon.c with lemon-orig.c I get the same errors that Sue is reporting.  This is strange.  Sue, is it possible that you have somehow replaced lemon.c with lemon-orig.c from the distribution?
Sent: Friday, August 25, 2017 2:28 AM
To: Mark Rivers; 'Sue Witherspoon'; Tech-talk
I am a bit confused over this exchange. The problem seems to be that
snl.h is not generated? Is that why you use a patched version of lemon?
Am 25.08.2017 um 00:55 schrieb Mark Rivers:
Hi Sue,
My apologies, I found that my version of seq 2-2-4 also has a modified version of lemon.c.  Here is the difference
Here is the patch:
[epics@gse-marccd2 lemon]$ diff -U3 lemon.c.orig lemon.c
--- lemon.c.orig        2016-11-25 11:50:21.000000000 -0600
+++ lemon.c     2017-08-24 17:37:51.910633792 -0500
@@ -403,6 +403,7 @@
   char *tokendest;         /* Code to execute to destroy token data */
   char *vardest;           /* Code for the default non-terminal destructor */
   char *filename;          /* Name of the input file */
+  char *outputdir;         /* Name of the output directory */
   char *outname;           /* Name of the current output file */
   char *tokenprefix;       /* A prefix added to token names in the .h file */
   int nconflict;           /* Number of parsing conflicts */
@@ -1576,6 +1577,7 @@
   static int statistics = 0;
   static int mhflag = 0;
   static int nolinenosflag = 0;
+  static char *outputdir = 0;
   static int noResort = 0;
   static struct s_options options[] = {
     {OPT_FLAG, "b", (char*)&basisflag, "Print only the basis in report."},
@@ -1594,6 +1596,7 @@
     {OPT_FLAG, "s", (char*)&statistics,
                                    "Print parser stats to standard output."},
     {OPT_FLAG, "x", (char*)&version, "Print the version number."},
+    {OPT_STR,  "o", (char*)&outputdir, "Directory for output files (default: same as input)."},
     {OPT_FSTR, "T", (char*)handle_T_option, "Specify a template file."},
     {OPT_FSTR, "W", 0, "Ignored.  (Placeholder for '-W' compiler options.)"},
     {OPT_FLAG,0,0,0}
@@ -1614,6 +1617,7 @@
   memset(&lem, 0, sizeof(lem));
   lem.errorcnt = 0;
+  lem.outputdir = outputdir;
   /* Initialize the machine */
   Strsafe_init();
@@ -1725,7 +1729,7 @@
   /* return 0 on success, 1 on failure. */
-  exitcode = ((lem.errorcnt > 0) || (lem.nconflict > 0)) ? 1 : 0;
+  exitcode = (lem.errorcnt > 0);
  exit(exitcode);
   return (exitcode);
@@ -2963,13 +2967,37 @@
   char *name;
   char *cp;
+  char *inputname;
+  int outputdirlen;
+  char *outputdir;
+  outputdir = lemp->outputdir;
+  if (!outputdir) {
+    outputdir = "";
+  outputdirlen = lemonStrlen(outputdir);
+  inputname = strrchr(lemp->filename,'/');
+  if (outputdirlen > 0 && inputname) {
+    inputname += 1;
+  } else {
+    inputname = lemp->filename;
+  name = (char*)malloc( outputdirlen + 1 + lemonStrlen(inputname) + lemonStrlen(suffix) + 1);
-  name = (char*)malloc( lemonStrlen(lemp->filename) + lemonStrlen(suffix) + 5 );
   if( name==0 ){
     fprintf(stderr,"Can't allocate space for a filename.\n");
     exit(1);
-  lemon_strcpy(name,lemp->filename);
+  lemon_strcpy(name,"");
+  if (outputdirlen > 0) {
+    lemon_strcat(name,outputdir);
+    if (outputdir[outputdirlen-1] != '/') {
+      lemon_strcat(name,"/");
+  lemon_strcat(name,inputname);
   cp = strrchr(name,'.');
   if( cp ) *cp = 0;
   lemon_strcat(name,suffix);
When I revert back to lemon.c.orig it fails with the same error you are getting.
I appear to have made that fix on November 25, 2016.
What is strange to me is that I cannot find any e-mail in which this change is discussed, either in my own e-mail or on tech-talk.
Perhaps Ben remembers this fix?  In any event it looks like it a known problems page for 2.2.4 needs to be added here?
https://urldefense.proofpoint.com/v2/url?u=http-3A__www-2Dcsr.bessy.de_control_SoftDist_sequencer_Installation.html-23download&d=DwIFAg&c=lz9TcOasaINaaC3U7FbMev2lsutwpI4--09aP8Lu18s&r=9jUweGhYkr3dLAaTIgDP3Q&m=PP_ckA1jhPZ-QbiyiQZuk3meUTEgBEmJBF83h7pcC-4&s=kQqap2WrNrxH1uICAxnD-6diVltj6NXv6NqMpCLbheg&e=
-----Original Message-----
Sent: Thursday, August 24, 2017 3:52 PM
To: Mark Rivers; Tech-talk
Hi Mark,
    Thanks for your response. The tech-talk thread I was talking about,
which is related (I think) to my problem is :
https://urldefense.proofpoint.com/v2/url?u=http-3A__www.aps.anl.gov_epics_tech-2Dtalk_2017_msg00087.php&d=DwIFAg&c=lz9TcOasaINaaC3U7FbMev2lsutwpI4--09aP8Lu18s&r=9jUweGhYkr3dLAaTIgDP3Q&m=PP_ckA1jhPZ-QbiyiQZuk3meUTEgBEmJBF83h7pcC-4&s=esu9G7qUBr8NwSb7yvi1pBY1ZMzqLTmsHGBeF50rHA8&e=   ..
Ben mentions many-core build machines and also GNUmake versions.... I'm
using 'GNU Make 3.81 built for i686-pc-linux-gnu'
But you are right, I am not generating the snl.h  file.
Do you know what rule triggers this generation?
Sue
On 08/24/2017 09:22 AM, Mark Rivers wrote:
Hi Sue,
I can't reproduce that problem.
My system:
seq 2.2.4
Redhat 6 (EPICS_HOST_ARCH=linux-x86-rhel6)
gcc 4.4.7-17
base 3.15.5
perl 5.10.1
I believe I have made only the following change to seq 2.2.4. Tthis was to fix a problem on Windows that was not related to the problem you are seeing.
corvette:seq-2-2-4/src/snc>diff -U3 snl.lt.orig snl.lt
--- snl.lt.orig 2017-01-13 08:38:51.976001963 -0600
+++ snl.lt      2017-01-13 08:35:39.777418847 -0600
@@ -829,11 +829,11 @@
      }else if( yyact <= YY_MAX_REDUCE ){
      }else{
        int yymx;
  #endif
  #ifndef NDEBUG
        if( yyTraceFILE ){
          fprintf(yyTraceFILE,"%sSyntax Error!\n",yyTracePrompt);
When I build seq 2.2.4 with the -sj options it builds fine with only the following output
[epics@gse-marccd2 seq-2-2-4]$ make -sj clean
m[epics@gse-marccd2 seq-2-2-4]$ make -sj
2 parsing conflicts.
Your first error is this:
../snl.re:16:17: error: snl.h: No such file or directory
So for some reason it is not finding snl.h.
From: [email protected] [[email protected]] on behalf of Sue Witherspoon [[email protected]]
Sent: Tuesday, August 22, 2017 2:59 PM
To: Tech-talk
Subject: Problems building seq 2.2.4 on Linux
I am having problems building seq 2.2.4 on linux:
Redhat 6 (linux-x86)
gcc version 4.4.7
Epics 3.15.5
perl v5.10.1
This is the complete output when building.
devl06 [195]: gmake rebuild
gmake -C ./configure clean
gmake[1]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/configure'
rm -rf O.rhel-6-ia32 O.Common
gmake[1]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/configure'
gmake -C ./src clean
gmake[1]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src'
gmake -C ./pv clean
gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/pv'
gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/pv'
gmake -C ./common clean
gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/common'
gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/common'
gmake -C ./seq clean
gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/seq'
gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/seq'
gmake -C ./lemon clean
gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/lemon'
gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/lemon'
gmake -C ./snc clean
gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/snc'
gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/snc'
gmake[1]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src'
gmake -C ./test clean
gmake[1]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/test'
gmake -C ./compiler clean
gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/test/compiler'
gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/test/compiler'
gmake -C ./validate clean
gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/test/validate'
gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/test/validate'
gmake -C ./unit clean
gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/test/unit'
gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/test/unit'
gmake[1]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/test'
gmake -C ./examples clean
gmake[1]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples'
gmake -C ./cmdButtons clean
gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples/cmdButtons'
gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples/cmdButtons'
gmake -C ./demo clean
gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples/demo'
gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples/demo'
gmake -C ./johng clean
gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples/johng'
gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples/johng'
gmake -C ./simple clean
gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples/simple'
gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples/simple'
gmake -C ./small clean
gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples/small'
gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples/small'
gmake -C ./pvGetAsync clean
gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples/pvGetAsync'
gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples/pvGetAsync'
gmake[1]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples'
gmake -C ./configure install
perl -CSD /usr/dvlepics/epics/R3.15.5.J0/bin/rhel-6-ia32/makeMakefile.pl O.rhel-6-ia32 ../..
mkdir O.Common
gmake -C O.rhel-6-ia32 -f ../Makefile TOP=../.. \
         T_A=rhel-6-ia32 install
gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/configure/O.rhel-6-ia32'
perl -CSD /usr/dvlepics/epics/R3.15.5.J0/bin/rhel-6-ia32/convertRelease.pl checkRelease
gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/configure/O.rhel-6-ia32'
gmake -C ./src install
gmake -C ./pv install
perl -CSD /usr/dvlepics/epics/R3.15.5.J0/bin/rhel-6-ia32/makeMakefile.pl O.rhel-6-ia32 ../../..
mkdir O.Common
gmake -C O.rhel-6-ia32 -f ../Makefile TOP=../../.. \
gmake[3]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/pv/O.rhel-6-ia32'
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -MM -MF pv.d  ../pv.c
gmake[3]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/pv/O.rhel-6-ia32'
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -c ../pv.c
/usr/bin/ar -rc    libpv.a        pv.o
/usr/bin/ranlib libpv.a
/usr/bin/g++ -o libpv.so.3.15.5 -shared -fPIC -Wl,-hlibpv.so.3.15.5 -L/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/lib/rhel-6-ia32 -L/a/devsite/dvlepics/epics/R3.15.5.J0/lib/rhel-6-ia32 -Wl,-rpath,/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/lib/rhel-6-ia32 -Wl,-rpath,/a/devsite/dvlepics/epics/R3.15.5.J0/lib/rhel-6-ia32           -rdynamic -m32            pv.o    -lca -lCom -Wl,-Bdynamic  -lpthread    -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/rhel-6-ia32/libpv.so.3.15.5
ln -s libpv.so.3.15.5 ../../../lib/rhel-6-ia32/libpv.so
Installing library ../../../lib/rhel-6-ia32/libpv.a
gmake -C ./common install
mkdir O.Common
gmake[3]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/common/O.rhel-6-ia32'
perl -CSD ../seq_release.pl 2.2.4 > ../O.Common/seq_release.h
Installing generated generic include file ../../../include/seq_release.h
gmake[3]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/common/O.rhel-6-ia32'
gmake -C ./seq install
mkdir O.Common
gmake[3]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/seq/O.rhel-6-ia32'
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -MM -MF seq_queue.d  ../seq_queue.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -MM -MF seq_cmd.d  ../seq_cmd.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -MM -MF seq_qry.d  ../seq_qry.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -MM -MF seq_prog.d  ../seq_prog.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -MM -MF seq_mac.d  ../seq_mac.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -MM -MF seq_if.d  ../seq_if.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -MM -MF seq_ca.d  ../seq_ca.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -MM -MF seq_task.d  ../seq_task.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -MM -MF seq_main.d  ../seq_main.c
gmake[3]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/seq/O.rhel-6-ia32'
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -c ../seq_main.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -c ../seq_task.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -c ../seq_ca.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -c ../seq_if.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -c ../seq_mac.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -c ../seq_prog.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -c ../seq_qry.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -c ../seq_cmd.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -c ../seq_queue.c
/usr/bin/ar -rc    libseq.a        seq_main.o seq_task.o seq_ca.o seq_if.o seq_mac.o seq_prog.o seq_qry.o seq_cmd.o seq_queue.o
/usr/bin/ranlib libseq.a
/usr/bin/g++ -o libseq.so.3.15.5 -shared -fPIC -Wl,-hlibseq.so.3.15.5 -L/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/lib/rhel-6-ia32 -L/a/devsite/dvlepics/epics/R3.15.5.J0/lib/rhel-6-ia32 -Wl,-rpath,/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/lib/rhel-6-ia32 -Wl,-rpath,/a/devsite/dvlepics/epics/R3.15.5.J0/lib/rhel-6-ia32           -rdynamic -m32            seq_main.o seq_task.o seq_ca.o seq_if.o seq_mac.o seq_prog.o seq_qry.o seq_cmd.o seq_queue.o    -lpv -lCom -Wl,-Bdynamic  -lpthread    -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/rhel-6-ia32/libseq.so.3.15.5
ln -s libseq.so.3.15.5 ../../../lib/rhel-6-ia32/libseq.so
Installing library ../../../lib/rhel-6-ia32/libseq.a
gmake -C ./lemon install
mkdir O.Common
gmake[3]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/lemon/O.rhel-6-ia32'
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -MM -MF lemon.d  ../lemon.c
gmake[3]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/lemon/O.rhel-6-ia32'
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -c ../lemon.c
/usr/bin/g++ -o lemon -Wl,-Bstatic -L/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/lib/rhel-6-ia32 -Wl,-rpath,/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/lib/rhel-6-ia32           -rdynamic -m32            lemon.o     -Wl,-Bdynamic  -lpthread    -lm -lrt -ldl -lgcc
Installing created executable ../../../bin/rhel-6-ia32/lemon
gmake -C ./snc install
mkdir O.Common
gmake[3]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/snc/O.rhel-6-ia32'
re2c -s -b -o lexer.c ../snl.re
perl -CSD /usr/dvlepics/epics/R3.15.5.J0/bin/rhel-6-ia32/mkmf.pl  -m lexer.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        lexer.o lexer.c
perl -CSD /usr/dvlepics/epics/R3.15.5.J0/bin/rhel-6-ia32/mkmf.pl  -m builtin.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        builtin.o ../builtin.c
perl -CSD /usr/dvlepics/epics/R3.15.5.J0/bin/rhel-6-ia32/mkmf.pl  -m sym_table.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        sym_table.o ../sym_table.c
perl -CSD /usr/dvlepics/epics/R3.15.5.J0/bin/rhel-6-ia32/mkmf.pl  -m gen_tables.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        gen_tables.o ../gen_tables.c
perl -CSD /usr/dvlepics/epics/R3.15.5.J0/bin/rhel-6-ia32/mkmf.pl  -m gen_ss_code.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        gen_ss_code.o ../gen_ss_code.c
perl -CSD /usr/dvlepics/epics/R3.15.5.J0/bin/rhel-6-ia32/mkmf.pl  -m gen_code.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        gen_code.o ../gen_code.c
perl -CSD /usr/dvlepics/epics/R3.15.5.J0/bin/rhel-6-ia32/mkmf.pl  -m analysis.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        analysis.o ../analysis.c
perl -CSD /usr/dvlepics/epics/R3.15.5.J0/bin/rhel-6-ia32/mkmf.pl  -m var_types.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        var_types.o ../var_types.c
perl -CSD /usr/dvlepics/epics/R3.15.5.J0/bin/rhel-6-ia32/mkmf.pl  -m node.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        node.o ../node.c
perl -CSD /usr/dvlepics/epics/R3.15.5.J0/bin/rhel-6-ia32/mkmf.pl  -m main.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        main.o ../main.c
gmake[3]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/snc/O.rhel-6-ia32'
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -c lexer.c
../snl.re: In function 'scan':
../snl.re:330: error: 'TOK_SLASH' undeclared (first use in this function)
../snl.re:330: error: (Each undeclared identifier is reported only once
../snl.re:330: error: for each function it appears in.)
../snl.re:331: error: 'TOK_MOD' undeclared (first use in this function)
../snl.re:285: error: 'TOK_NAME' undeclared (first use in this function)
../snl.re:287: error: 'TOK_INTCON' undeclared (first use in this function)
../snl.re:323: error: 'TOK_PERIOD' undeclared (first use in this function)
../snl.re:333: error: 'TOK_GT' undeclared (first use in this function)
../snl.re:332: error: 'TOK_LT' undeclared (first use in this function)
../snl.re:328: error: 'TOK_ADD' undeclared (first use in this function)
../snl.re:327: error: 'TOK_SUB' undeclared (first use in this function)
../snl.re:329: error: 'TOK_ASTERISK' undeclared (first use in this function)
../snl.re:324: error: 'TOK_AMPERSAND' undeclared (first use in this function)
../snl.re:334: error: 'TOK_CARET' undeclared (first use in this function)
../snl.re:335: error: 'TOK_VBAR' undeclared (first use in this function)
../snl.re:318: error: 'TOK_EQUAL' undeclared (first use in this function)
../snl.re:325: error: 'TOK_NOT' undeclared (first use in this function)
../snl.re:313: error: 'TOK_SEMICOLON' undeclared (first use in this function)
../snl.re:314: error: 'TOK_LBRACE' undeclared (first use in this function)
../snl.re:315: error: 'TOK_RBRACE' undeclared (first use in this function)
../snl.re:316: error: 'TOK_COMMA' undeclared (first use in this function)
../snl.re:317: error: 'TOK_COLON' undeclared (first use in this function)
../snl.re:319: error: 'TOK_LPAREN' undeclared (first use in this function)
../snl.re:320: error: 'TOK_RPAREN' undeclared (first use in this function)
../snl.re:321: error: 'TOK_LBRACKET' undeclared (first use in this function)
../snl.re:322: error: 'TOK_RBRACKET' undeclared (first use in this function)
../snl.re:326: error: 'TOK_TILDE' undeclared (first use in this function)
../snl.re:336: error: 'TOK_QUESTION' undeclared (first use in this function)
../snl.re:312: error: 'TOK_NE' undeclared (first use in this function)
../snl.re:311: error: 'TOK_EQ' undeclared (first use in this function)
../snl.re:308: error: 'TOK_OROR' undeclared (first use in this function)
../snl.re:301: error: 'TOK_OREQ' undeclared (first use in this function)
../snl.re:300: error: 'TOK_XOREQ' undeclared (first use in this function)
../snl.re:307: error: 'TOK_ANDAND' undeclared (first use in this function)
../snl.re:299: error: 'TOK_ANDEQ' undeclared (first use in this function)
../snl.re:296: error: 'TOK_MULEQ' undeclared (first use in this function)
../snl.re:306: error: 'TOK_POINTER' undeclared (first use in this function)
../snl.re:305: error: 'TOK_DECR' undeclared (first use in this function)
../snl.re:295: error: 'TOK_SUBEQ' undeclared (first use in this function)
../snl.re:304: error: 'TOK_INCR' undeclared (first use in this function)
../snl.re:294: error: 'TOK_ADDEQ' undeclared (first use in this function)
../snl.re:309: error: 'TOK_LE' undeclared (first use in this function)
../snl.re:303: error: 'TOK_LSHIFT' undeclared (first use in this function)
../snl.re:293: error: 'TOK_LSHEQ' undeclared (first use in this function)
../snl.re:310: error: 'TOK_GE' undeclared (first use in this function)
../snl.re:302: error: 'TOK_RSHIFT' undeclared (first use in this function)
../snl.re:292: error: 'TOK_RSHEQ' undeclared (first use in this function)
../snl.re:290: error: 'TOK_FPCON' undeclared (first use in this function)
../snl.re:270: error: 'TOK_WHILE' undeclared (first use in this function)
../snl.re:269: error: 'TOK_WHEN' undeclared (first use in this function)
../snl.re:268: error: 'TOK_VOID' undeclared (first use in this function)
../snl.re:267: error: 'TOK_UNSIGNED' undeclared (first use in this function)
../snl.re:266: error: 'TOK_UNION' undeclared (first use in this function)
../snl.re:277: error: 'TOK_UINT32T' undeclared (first use in this function)
../snl.re:275: error: 'TOK_UINT16T' undeclared (first use in this function)
../snl.re:273: error: 'TOK_UINT8T' undeclared (first use in this function)
../snl.re:264: error: 'TOK_TO' undeclared (first use in this function)
../snl.re:265: error: 'TOK_TYPENAME' undeclared (first use in this function)
../snl.re:257: error: 'TOK_SS' undeclared (first use in this function)
../snl.re:263: error: 'TOK_SYNC' undeclared (first use in this function)
../snl.re:261: error: 'TOK_SYNCQ' undeclared (first use in this function)
../snl.re:260: error: 'TOK_STRUCT' undeclared (first use in this function)
../snl.re:259: error: 'TOK_STRING' undeclared (first use in this function)
../snl.re:258: error: 'TOK_STATE' undeclared (first use in this function)
../snl.re:256: error: 'TOK_SIZEOF' undeclared (first use in this function)
../snl.re:255: error: 'TOK_SHORT' undeclared (first use in this function)
../snl.re:254: error: 'TOK_RETURN' undeclared (first use in this function)
../snl.re:253: error: 'TOK_PROGRAM' undeclared (first use in this function)
../snl.re:252: error: 'TOK_OPTION' undeclared (first use in this function)
../snl.re:251: error: 'TOK_MONITOR' undeclared (first use in this function)
../snl.re:250: error: 'TOK_LONG' undeclared (first use in this function)
../snl.re:248: error: 'TOK_IF' undeclared (first use in this function)
../snl.re:249: error: 'TOK_INT' undeclared (first use in this function)
../snl.re:272: error: 'TOK_INT8T' undeclared (first use in this function)
../snl.re:276: error: 'TOK_INT32T' undeclared (first use in this function)
../snl.re:274: error: 'TOK_INT16T' undeclared (first use in this function)
../snl.re:246: error: 'TOK_FOR' undeclared (first use in this function)
../snl.re:247: error: 'TOK_FOREIGN' undeclared (first use in this function)
../snl.re:245: error: 'TOK_FLOAT' undeclared (first use in this function)
../snl.re:244: error: 'TOK_EXIT' undeclared (first use in this function)
../snl.re:243: error: 'TOK_EVFLAG' undeclared (first use in this function)
../snl.re:242: error: 'TOK_ENUM' undeclared (first use in this function)
../snl.re:241: error: 'TOK_ENTRY' undeclared (first use in this function)
../snl.re:240: error: 'TOK_ELSE' undeclared (first use in this function)
../snl.re:239: error: 'TOK_DOUBLE' undeclared (first use in this function)
../snl.re:238: error: 'TOK_CONTINUE' undeclared (first use in this function)
../snl.re:237: error: 'TOK_CONST' undeclared (first use in this function)
../snl.re:236: error: 'TOK_CHAR' undeclared (first use in this function)
../snl.re:235: error: 'TOK_BREAK' undeclared (first use in this function)
../snl.re:234: error: 'TOK_ASSIGN' undeclared (first use in this function)
../snl.re:298: error: 'TOK_MODEQ' undeclared (first use in this function)
../snl.re:297: error: 'TOK_DIVEQ' undeclared (first use in this function)
../snl.re:358: error: 'TOK_STRCON' undeclared (first use in this function)
../snl.re:427: error: 'TOK_CCODE' undeclared (first use in this function)
gmake[3]: *** [lexer.o] Error 1
gmake[2]: *** [install.rhel-6-ia32] Error 2
gmake[1]: *** [snc.install] Error 2
gmake: *** [src.install] Error 2
devl06 [196]:
I saw a thread in tech-talk that appeared to address this but after applying the same fix to src/snc/Makefile  by adding: HDEPENDS_METHOD=MKMF, I still get the error.  snl.h is not being generated......
Any help would be most appreciated!
Sue Witherspoon
Staff Computer Scientist
Accelerator Controls Software
757-269-7579
Thomas Jefferson National Accelerator Facility
Sue Witherspoon
757-269-7579
Sue Witherspoon
757-269-7579
Problems building seq 2.2.4 on Linux Sue Witherspoon
RE: Problems building seq 2.2.4 on Linux Mark Rivers
Re: Problems building seq 2.2.4 on Linux Sue Witherspoon
Re: Problems building seq 2.2.4 on Linux Ben Franksen
Prev: motor record behavior when VBAS == VELO Kevin Peterson
Next: RE: Problems building seq 2.2.4 on Linux Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Problems building seq 2.2.4 on Linux Mark Rivers
