Subject: Re: Archiver: Problems with disconnected PVs
To: Gabriel de Souza Fedel <[email protected]>
Date: Fri, 1 Sep 2017 09:21:51 -0500
On 09/01/2017 07:14 AM, Gabriel de Souza Fedel wrote:
> Hi,
> I'm having some problems with an epics archiver instance
> (https://slacmshankar.github.io/epicsarchiver_docs/).
> Some PVs are running normally, and I can access on archiver machine with
> caput/camonitor, but appears disconnected on archiver. Some of these PVs
> was working before, and stopped at some moment, another never connect.
> I tried to find some error at logs, but nothing was registered
> Has anyone had this kind of problem? Any idea how to debug/solve this?
This seems like it might be a CA client configuration issue.  Some
questions:
1. Can you confirm that you can access all PVs to be archived with
'caget' from the host running AA?
2. Do you have any special CA configuration on the AA host?  What does
running "env|grep EPICS" show?
3. Repeat #1 with a java CA client like cs-studio.  If a GUI isn't
convenient then you might try:
https://github.com/mdavidsaver/yascaif/releases
> java -jar yascaif-bundle-0.4a.jar get <pvname>
Re: Archiver: Problems with disconnected PVs Gabriel de Souza Fedel
Prev: Re: Archiver: Problems with disconnected PVs Dirk Zimoch
Next: Re: Another EPICS site, CSNS now producing neutrons Dave Gurd
Prev: Re: Archiver: Problems with disconnected PVs Andrew Johnson
Next: Re: Archiver: Problems with disconnected PVs Gabriel de Souza Fedel
