1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Archiver: Problems with disconnected PVs
To: Michael Davidsaver <[email protected]>
Date: Fri, 1 Sep 2017 13:57:38 -0300
Em 01-09-2017 11:21, Michael Davidsaver escreveu:
On 09/01/2017 07:14 AM, Gabriel de Souza Fedel wrote:
I'm having some problems with an epics archiver instance
(https://slacmshankar.github.io/epicsarchiver_docs/).
Some PVs are running normally, and I can access on archiver machine with
caput/camonitor, but appears disconnected on archiver. Some of these PVs
was working before, and stopped at some moment, another never connect.
I tried to find some error at logs, but nothing was registered
Has anyone had this kind of problem? Any idea how to debug/solve this?
Thank you for the answer.
My answers are bellow:
This seems like it might be a CA client configuration issue.  Some
questions:
1. Can you confirm that you can access all PVs to be archived with
'caget' from the host running AA?
Yes, I make new tests now, e everything working well with caget
2. Do you have any special CA configuration on the AA host?  What does
running "env|grep EPICS" show?
Nothing special:
EPICS_HOSTNAME=linux-x86_64
EPICS_BASE=/usr/local/epics/base
EPICS_EXTENSIONS=/usr/local/epics/extensions
EPICS_HOST_ARCH=linux-x86_64
EPICS_LOCAL=/usr/local/epics/local
EPICS_MODULES=/usr/local/epics/modules
3. Repeat #1 with a java CA client like cs-studio.  If a GUI isn't
convenient then you might try:
https://github.com/mdavidsaver/yascaif/releases
java -jar yascaif-bundle-0.4a.jar get <pvname>
Using yascaif I can access the PVs normally too
Gabriel Fedel
Software de Operação das Linhas de Luz
Laboratório Nacional de Luz Síncrotron – (LNLS)
Centro Nacional de Pesquisa em Energia e Materiais (CNPEM)
[email protected] | +55 (19) 3512 1226
www.lnls.cnpem.br
Archiver: Problems with disconnected PVs Gabriel de Souza Fedel
Re: Archiver: Problems with disconnected PVs Michael Davidsaver
Prev: Re: Archiver: Problems with disconnected PVs Shankar, Murali
Next: Re: Archiver: Problems with disconnected PVs Gabriel de Souza Fedel
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Archiver: Problems with disconnected PVs Michael Davidsaver
Next: Re: Archiver: Problems with disconnected PVs Shankar, Murali
