Subject: Re: Archiver: Problems with disconnected PVs
To: "Shankar, Murali" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 1 Sep 2017 14:52:25 -0300
Em 01-09-2017 13:39, Shankar, Murali escreveu:
This seems like it might be a CA client configuration issue
This is the most likely case. The engine prints out it's CAJ
configuration on startup and you should be able to see this in your logs.
I didn't find it. I find engine/logs/catalina.err, is there another location?
You can try a couple of things. You can pause/resume the PV's in
question and see if they reconnect back. You can also look in the IOC's
logs and see if there is anything interesting going there.
pause/resume I tried. IOC's log on ioc machine right? apparently there is no errors (on epics console).
Regards and thank you for the answer
Murali
Gabriel Fedel
Software de Operação das Linhas de Luz
Laboratório Nacional de Luz Síncrotron – (LNLS)
Centro Nacional de Pesquisa em Energia e Materiais (CNPEM)
[email protected] | +55 (19) 3512 1226
www.lnls.cnpem.br
Re: Archiver: Problems with disconnected PVs Shankar, Murali
Prev: Re: Archiver: Problems with disconnected PVs Gabriel de Souza Fedel
Next: Re: Archiver: Problems with disconnected PVs Shankar, Murali
Prev: Re: Archiver: Problems with disconnected PVs Shankar, Murali
