>> This seems like it might be a CA client configuration issue
This is the most likely case. The engine prints out it's CAJ configuration on startup and you should be able to see this in your logs.
You can try a couple of things. You can pause/resume the PV's in question and see if they reconnect back. You can also look in the IOC's logs and see if there is anything interesting going there.
Murali
- Re: Archiver: Problems with disconnected PVs Gabriel de Souza Fedel
Re: C++ multi threaded application. Andrew Johnson
<2017>
2025
2026
<2017>
2025
2026
ANJ, 21 Dec 2017 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
