1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Switched PDUs with EPICS support
To: [email protected]
Date: Thu, 7 Sep 2017 18:50:45 -0700
Hi All,
Thanks for all your responses.
We have found that we can use the APC PDUs with a standard cord length but now we face another challenge and that is that the B version of the desired PDU (like AP7900B [1]) has updated firmware .
Does anybody have EPICS support for this model/FW?
Žiga
[1] http://www.apc.com/shop/us/en/products/Rack-PDU-Switched-1U-15A-100-120V-8-5-15/P-AP7900B
On 10.5.2017 13:36, Bruce Hill wrote:
Hi Ziga,
We're using snmp to control PDU's from Leviton, iBootBar, and Sentry via EPICS.
Source code available here:
http://www.slac.stanford.edu/~bhill/epics-pcds/ioc-R3.14.12/common/Leviton/Leviton-R1.28.2.tar.gz
http://www.slac.stanford.edu/~bhill/epics-pcds/modules-R3.14.12/snmp/snmp-R1.1.0-2.7.0.tar.gz
Cheers,
- Bruce
On 05/10/2017 12:06 AM, [email protected] wrote:
few months ago I developed an EPICS IOC for ATEN PDU
(PE8208 - metered and switched) using SNMP device support
module (https://groups.nscl.msu.edu/controls/files/devSnmp.html);
source code available here:
    https://github.com/gtortone/ATEN-EPICS
Gennaro
On Tue, 9 May 2017, Žiga Oven wrote:
Hi All,
We are looking for alternative to APC switched PDUs as we would like to have cord longer than standard APC length of 12 feet. http://www.apc.com/shop/us/en/products/Rack-PDU-Switched-1U-15A-100-120V-8-5-15/P-AP7900B
I have checked the EPICS modules page and I have found several other options with existing support, but they all look a bit outdated (based on part numbers on the page and cross-referencing them with current vendor part numbers).
Are there other switched PDUs with EPICS support in use besides APC?
Žiga
Switched PDUs with EPICS support Žiga Oven
Re: Switched PDUs with EPICS support [email protected]
Re: Switched PDUs with EPICS support Bruce Hill
Prev: Re: C++ multi threaded application. Andrew Johnson
Next: data refresh and add pv 梁雅翔
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Switched PDUs with EPICS support Bruce Hill
Next: Release 0.7.0 of pvaPy Andrew Johnson
